idahos13 wrote:Here are the pics.This BOSS hub sucks! It doesnt turn my turn signals off, and my horn that came with my steering wheel, has two wires a power and a ground. The hub only has a power wire. So I need to figure out how to make my horn work.
Where'd you order your NRG Steering Wheel? Cause when I ordered mine, same one as yours, it didn't come with the Horn Button.
And for the signals not working, there should've been a tripper that came with the HKB Kit that you put in the two holes on the hub to trip the signal.
We have the same hub, and what I'm thinking of doing mine is that cut a brass plate and just add it to the existing one since the HKB hub metal contact is too small.
This might help:
zer...-vert
