Oh, I didnt know that lol.White Comet wrote:iirc, the engine was running in teh car before he pulled it. true if hes swapping i wouldnt mess w/ anything at first. but if it was running when he pulle dit it shoudl run when it goes back in
lol it is fine. i never said anything about it, but it did run great even at 14psi. oh boy. imagine 22 psi on a gt2871r .86 crazybgsr240 wrote:
care to elaborate, if his wiring was fine when the engine was pulled why woudl it be bad going back in?bgsr240 wrote:
What I meant was that I didnt know that the engine was already in the car and running before he started the build. You are right if it ran before then it should run after lol. Sorry, I wasn't trying to say anything by it.White Comet wrote:care to elaborate, if his wiring was fine when the engine was pulled why woudl it be bad going back in?
last time i check they cost the same.bgsr240 wrote:Well to be honest I'm probably going to end up with the gt2871r .64 AR because it cost less, less lag, etc. I could almost do a valvetrain upgrade with the money I would save over the gt30r.
HAHA... this is awesome. Again I am comparing the gt2871r to gt3071r.idahotuner wrote:last time i check they cost the same.
well i am going with it for to reasons. more traction on the launch and better gas milage, since it has a longer spool thne if you dot rev as high you wil lget better gas miisalge casue the turbo wont be kicking in as soon.White Comet wrote:yeah there the same but the .86 has too high of a power band for my liking
That's kinda what I thought, but I wanted someone else's opinion. Also forgot to say that new springs and retainers would be installed with the cams.White Comet wrote: theres no sense in buy cams and then doing it again
idahotuner wrote:Yeah I did, but it didnt really answer my question...idahotuner wrote:therrer isa cam shaft mega thread i would suggest reading through it
retainers arnt a huge deal, and only allow for small gains in the rpms, but springs area must.bgsr240 wrote:Also forgot to say that new springs and retainers would be installed with the cams.
