I am telling you guys. This will fix it. Be sure to check the fuses under the hood also. I think there is a 20 amp in there that can cause this also. This happened on my s13 once after i jumped off a friend. (Never will I jump off another car. Blew my radio fuse behind the dash also. What a mess to pull out all my aftermarket radio stuff to get to that one. I swore it off after that. Nor would I accept a jump. Just a good push will do.
It would probably be a good idea to have a 12v test light handy since you can't always "see" a bad fuse. Check both sides of every fuse if you have to with the ign off. If you find one with power to one side but not the other, it's toast.
Now if someone could just fix my vibration problem that i posted in the nistech section, that would be nice. Hehehe....
