I am Technoman »
https://forums.nicoclub.com/i-am-technoman-u3057.html
Tue Oct 21, 2003 5:22 pm
The leg touch!
If you are both sitting, the situation gets slightly different. You can't be reaching over to accidentally be brushing against her breast. So in this case, you can use other parts of you body to make contact with hers, after all, it’s about the physical contact! If you are both on bar stools and you are facing each other, you can make both of your legs softly interlock with hers during an attempt to reach over and better hear what she is saying.If you are both sitting at a table, facing each other, at least your ankles should touch, hopefully proceeding to a footsie, where you run your ankle along her leg. If you are both sitting at a table, perpendicular to each other, your knees can touch.If you are both in a booth, next to each other, your elbows, legs and knees can come in contact.If you are sitting on a bar stool, and she comes around but doesn't have a seat, offer yours. If she says no (they usually do) then stand up any way, claiming you sat too much at the office. Then, if you are both standing up, you can carry out the boob touch.After you carry out the whispering, the boob touch or the leg touch techniques for twenty minutes or so, you will notice that she will be enjoying it as much as you are. That's good! This means that you only are two steps from bringing her back to the C-R-I-B!
:rolleyes
