What? does the car not run?Vicious176 wrote:What are some low tier mods I can do now or until I have to quit buying parts to get it running.
Well, there is more info than that, but yeah, you've pretty much got it. (The silvias continued production longer than 240s, etc)jordanh wrote:hey guys, im kind of new to the 240 sx's. i was curious as to what the differences were in a silvia and a 240sx. i thought i found the answer which was that the silvia was a japanese model with a sr20 and the 240sx was a us model with the ka.
also was the rb 25 in any other car but the skyline?
if this never what?Vicious176 wrote:Well the story is I was on a dirt road, the clutch slipped, over revved, upshifted, launched into a tree. Only damage done was cosmetic and radiator. What bugs me is the people who own the tree are getting 1.2k where there was no damage to it, on not of that, I didn't know it was on someone's property so when I made the insurance claim they said it was safe to drive home, end up its a large property and I got hit and run on tree.
I'll post damage pics later but i've stripped everything since. Since my clutch went out I upgraded to a exedy stage two B&M SS and the greddy counterweight, I regret not buying a new flywheel, a Koyo rad and a CF hood. Now I just need lights and radsupport, bumper support and things to finish the kouki conversion. Unless they find something else is messed up while working on it on my something happened to my suspesion, although it seems fine.
Keep in mind if this never
posted too soon, was going to say i'd be buying performance parts such as suspension and intake rather than the 3kish i've spent getting to where I am now.PapaSmurf2k3 wrote:
if this never what?
Well... the wire was extremely hard to pull out. It's a pretty fat wire and has also become harden. What can I use to pull it out easier?PapaSmurf2k3 wrote:I'm not 100% sure, but that looks promising. The only thing I know is that it is WAY easier to replace the PCV valve on the KA24E than the DE.
Pull it out and check it out. If it looks like a PCV valve, or rather looks like the new one you have to put in, then go for it!
So its okay to fill it up with 91 when im at or near E? I'm assuming the 91 would dilute the 87.PapaSmurf2k3 wrote:well if you are damn near empty, that is why it takes a while to start. Fill that puppy up with premium, because that is what the car is supposed to run on anyway.
If you are comfortable with that type of camber, then leave it. If you have a bunch of money burning a hole in your pocket, then go for it.lamchops wrote:i just lowered my 240 and its sitting at negative camber and about -0.1 degrees on the toe for the rear axle should i just purchase an adjustable camber kit or should i purchase both an adjustable camber kit and also an adjustable toe kit for the rear axle???
Yes, it is possible to put a silvia front end on a 240. There are many NICO members who have done it. Generally, if you are going to do that, you can probably find a car that has some front end damage and save some cash during the buy, seeing as how you will be replacing all that anyway. S13 or S14 is personal preference, as well as budget. Do what you want.You do not need an SR20DET to drift. The 240 could probably drift with a damn weed wacker engine in it. Again, the type of engine is a matter of preference.KAs have more torque down low, but SRs tach higher and make more power in the higher RPM range. KA would be easier because well... its already in the car. The 3 most common motors are the SR20DET, the KA(E or DE), and the CA18DET. NICO has subforums for every one of these motors.240sx_boy wrote:Hey I'm looking at getting an 89 240SX but I need to know a few things before I fix on getting it. It's a pignose and in really good condition but I'm not sure if it would be better to get an S14. Also is it possible to put a Silvia front end on a 240? I also need to know the ups and downs about the different kinds of engines. Is the SR20DET the best one for drifting?
