Tom’s red s13 240sx wrote:does anyone know where i can get a whole sr20det swap for cheap?
This is largely dependent on whether or not you plan to rebuild it yourself. If you plan to do the job yourself and possibly build additional engines in the future, then you'll need to get the parts and the specialized tools for the job. Minimum for most rebuilds:Ringsbearings (rods and mains)rear main sealfront oil sealhead gasketvalve cover gasketfront oil sealRTV sealant (I used a Ford Motorcraft sealant after a fair bit of research)Probably want to replace timing chain and possibly the sprockets and tensionersvalve sealscylinder head boltscylinders will need to be honed or bored cylinder hone if necessaryvalve spring compressorpiston ring compressorpiston ring pliersmeasuring equipment (calipers, micrometers)FSM specslots of mineral spirits to clean the gunkI use Lucas oil stabilizer for assembly lube. It's stickier, cheaper, and I think it does the job better than the assembly lube you buy as suchProbably a new clutch and pilot bushing while you're at itIf you're rebuilding a KA24E and plan to go boost on the cheap, you might want to swap in a set of KA24DE pistons. It should lower the compression ratio down some.majiga wrote:hey guys im new here too just like everyone else posting questions in this thread. I just bought a 240 the other day and im looking to rebuild the engine. it has 256,000 miles on it and it burns oil when you accelerate. i dont know much about 240's let alone cars in general. ive been trying to read and find out about them constantly. could some one be so kind to point me in the right direction for what to buy to rebuild the engine. if you could just make a little list of things you suggest it would be greatly appreciated. btw im not looking to spend tons of money. maybe keep the rebuild under a 1000 if that is possible? oh and can you tell me which brands you suggest.
If you could also tell me a cheap yet sufficient turbo and where i could find it. i am definately looking to turbo my sohc after the rebuild. thanks
No problem. Glad to help.majiga wrote:sweet man thanks for all the info. i appreciate it.
yeah, as far as I know.... yes...btw, the driver of the 2 tone coupe is a member here, you could ask him yourself... zerothread?id=213668majiga wrote:for an s13 to an s14 headlight conversion.
there is this fender kit with mounts on ebay here.
http://cgi.ebay.com/ebaymotors...br%3E
would all i need besides that is the headlights, front bumber, and hood?thanks.
Modified by majiga at 8:02 AM 6/2/2007
assuming that you or the previous owner didn't swap the engine... it should say the engine code on the firewall right next to your vin. most common engines in these suckers are the KA24DE, KA24E, SR20DET, CA18DET... unless it's 6-cylinder, then it's probably an rb20/25/26Carbonjun wrote:I just brough a 240. This is what I know its has tein suspension, Greddy full cat exhaust, 5 lug, cloth interior, sunroof, 17' rims, air cold Injen and its stick. I want to know what egine I have and what type of setup are out there for my car. Since this is my second project car I'm working on. Thanks guys
Well I've spend over 50k on my eg! Looking to push it the max. Someone told me that there's a 240 with a viper engine? Is that possible? Thanks for the info..PapaSmurf2k3 wrote:Take a pic of your engine bay and post it up, we will tell you what engine it is. As for what engine is possible... any engine you ever want is possible, it depends on how deep your pockets are.
have you seen a viper engine before? find a picture of a viper engine, then ask yourself that same question again...Carbonjun wrote: Someone told me that there's a 240 with a viper engine? Is that possible? Thanks for the info..
Thats what I've been told by some from RPMNYC.com. Well then I might just do that project then if its possible.adrians_s13 wrote:have you seen a viper engine before? find a picture of a viper engine, then ask yourself that same question again...
My interior on my s13 has no ripps, tears, cig burns, no cracked dash (typical probs in other 240s), just depends on who you get it from and if they take car of it. in my case it was an old man who had it. only thing that is a prob for me is the fuse blew in the automatic seat belt slider but a new fuse and it should be a quick fixtoasty wrote:hey guys, im new here - dont even have a 240 yet. i was wondering what the build quality of the 240sxs is? specifically interiors on s13. my mitsu 3000gt is terrible, and this is somthing i care about when looking at a car. thanks.
well that all depends, if you do go that route, the guy mightve been a real dummy and never let his turbo cool down after stopping.. he mightve got too big of components for the engine (has happened to me when i went to look at a SR20'd 240 one time) but just simple stuff like that.. if you get it from someone who knows there 240s and is really knowledgeable about "turbo'd" engines than it should be fine.. But IMO i would just get a 240 with a stock KA engine and buy a SR yourself cause you know how it has been treated and you know where its coming from..toasty wrote:also - i know this has probably been answered a thousand times - but is it worth it to buy an already swapped sr20det motor in say an s13, or start from scratch?
my gf's brother has an srt-10, and lemme tell you... that engine is fvcking huge... you'd have to push not only the firewall back, but the driver and passenger seats back where the rear seats areCarbonjun wrote:Thats what I've been told by some from RPMNYC.com. Well then I might just do that project then if its possible.
1546 whp!adrians_s13 wrote:find a picture of a viper engine
G1sdaname wrote:well I mean on Idle if I accelarate over 1500 it will stop shaking. I just changed 4 spark plugs like a week ago. So you think that one of the spark plugs went bad already or was bad from the start?
you know that's a photoshop right?p1rat3 wrote:The viper engine fits in the integra, so somehow it must fit in a 240
Check for vacuum leaks. Is it manual or automatic?G1sdaname wrote:also when I accelarate now it slightly shakes no matter what gear I'm on and when I maintain a certain speed it stops. Very annoying!
