I don't think you wanna know.Razi wrote: What are you taking it for?
I got my nuts decommissioned yesterday.Razi wrote: What are you taking it for?
No, it won't. The SOHC's compressor only works a little bit with the CA18DET. The SR and KA24DE are not compatible also for another reason, they don't use the same kind of refrigerant as the SOHC does.AZ89two4Tsx wrote:It's a single cam, and I really don't want the next engine in there to be a single cam. Will my compressor work on a dual cam, or dare I say SR?
Re-manufactured alternators are crap, no matter WHAT company you buy from.xekushnr wrote:Get that alternator tested though. I've seen them come out of the box bad.
x2xekushnr wrote:Did you have the alternator bench tested? I'm assuming that the old alternator killed the battery, if thats the case you may need a new battery and that might be it. Get that alternator tested though. I've seen them come out of the box bad.
The new compressor is R134a or whatever you call it, not r12.Dattebayo wrote:
Is there a way to tune it so the boost hits quicker?Dattebayo wrote:Yeah, all the boost hits kinda late on them tho.
thanks dude!xekushnr wrote:Did you have the alternator bench tested? I'm assuming that the old alternator killed the battery, if thats the case you may need a new battery and that might be it. Get that alternator tested though. I've seen them come out of the box bad.
King Ranzo wrote:I enjoyed my single cam when I had it. Good power and good torque. I didn't mind it. Never had a problem with it. I say save up the money for a CA18DET. They are pretty good little motors. Good out of the box horsepower.
Yes, but it's really not too safe for the motor and should only be used once in a very long while. One of the mods in the CA forum had a thread about it a few months or weeks back I think?King Ranzo wrote:Is there a way to tune it so the boost hits quicker?
Uh, whatever. Like you know anything.AZ89two4Tsx wrote:
I don't even know what that's for.AZ89two4Tsx wrote:
Ah I see. Well aside from the boost kicking in late, it's still a good motor.Dattebayo wrote:
