I jumped on the bandwagon! :D
Future_gohan
Car: 91 240sx, 91 vert
Logan76 wrote:If your crank journals are all still shiney and nice, you may want to take it to a machine shop just to have it checked out, but I would re-use it, and check the big ends of rod's out also.
What do you mean the big end of the rods?
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
use your head bro...have you ever looked at a rod?? lulz
Logan76
Car: Junk
The larger end, the bearing journal on the rod. Your bearings have an inner and outter race (common term used on ball/roller bearing's, pretty much means the outside and inside face) Your inner race contacts the crank journal and your outter race contacts your rod journal.
Future_gohan
91SilviaKs wrote:use your head bro...have you ever looked at a rod?? lulz
Just making sure? lol
Okay so I was looking at the crank..and they're all pretty shiny with no scratches except one..its doesn't seem that bad but its deff messed up..i'll post some pictures to see if you guys can see it..
Future_gohan
now..if this is the case, how much does machine work run estimate?
Future_gohan
Now thats the spot..and the wtf it looks like something got shaved off. should it be that way...?
edit.//
I don't understand how do I find bigger bearings..i've been looking on enjuku and they don't sell different sized ones, so do I have to custom order a set? or should I get a new crank?
Modified by Future_gohan at 10:10 PM 5/6/2009
Logan76
Car: Junk
You could get a new crank, but just have that one turned down and balanced. You may even be able to find oversized bearings from your dealership? Cutting bearing journals is a common thing, bearings are out there, trust me.
Koshin
depending on the damage, itll prolly polish out....but even if its machined you can just get oversized bearings....
Future_gohan
I mean, that part of the crank only looks scuffed up, you can't even feel it to the touch..I'm pretty new to tearing apart the bottom end so I'm not sure how to go about this..
Future_gohan
91SilviaKs wrote:depending on the damage, itll prolly polish out....but even if its machined you can just get oversized bearings....
there isn't any deep cuts, its only just scuffed up..if I JUST polish it, can i just use my oem bearings?
Logan76
Car: Junk
the wtf part is there they remove material for balancing, notice the holes drilled?
Future_gohan
Okay so that's suppose to be there...good. I've just never actually took a crank out to see what it looks like. lol First for everything i guess.
Logan76
Car: Junk
When you buy a new oil pickup and pump, but the pickup from an S14, they have a bigger opening and were re-designed a tad.
If you want a nice running stock SR, I would get your crank issue sorted out and the correct bearings, you may want to pick up another used OEM rod for that cyl. Just a new gasket kit + ring kit and a quick hone would probably throw that thing back together nicely. Have your valve seals replaced while you have it apart too.
Future_gohan
Logan76 wrote:When you buy a new oil pickup and pump, but the pickup from an S14, they have a bigger opening and were re-designed a tad.
And the pickup bolts right up to the sr?
yeah, I might use the stock bottom end..get new rings and such, and then build a nice head, try get get some good rpms out of it.. get some cams lifters spring etc. the guy gave me 8 pistons..i have no idea which where the ones actually in the engine lol
Logan76
Car: Junk
if your going as far as to build the head, I would atleast get forged pistons. Yes the S14 SR pickup will bolt up, its going to look a tad different, it bolts up though.
Future_gohan
Alrighty. Thanks for all the help I'm going to see how much it is to get the crank polished and such and see where it takes me! I might just get rods too and call it even..but I'll decide that later.
Future_gohan
I went ahead and organized everything to see what I have..
here is some of the block and parts cleaned up..
Logan76
Car: Junk
I wish I could find deals like that lol. Nice score.
Future_gohan
I love getting deals...lol
Logan76
Car: Junk
The last deal I got I threw in the trash, a perfectly good 4 bolt main SBC long block with .30 over bore. Had bad valve seals and an oil consumption problem due to that fact. It sat in my garage a few years so I sent it to the scrap yard, stupid me.
Future_gohan
Ouchh. I'm poor so I always gotta get deals..sometimes crazy ones lol
Logan76
Car: Junk
I think the majority of 240 owners are poor, everyone has a budget, if we didn't we would have bugatti veyron's. lol
Future_gohan
haha yeah thats true...
Koshin
you getting things straightened out huh???
Future_gohan
91SilviaKs wrote:you getting things straightened out huh???
best as i can...lol
Future_gohan
Someone stopped by and welcomed me to the bandwagon. haha
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
safin wrote:
SRRRRRRRRRRRR!!!!!
congrats! it is a redtop
BTW, what would you guys call this thing? forgive my ignorance...por favor
Thats the vent for the crankcase, it connects to the valve cover.
Future_gohan wrote:Someone stopped by and welcomed me to the bandwagon. haha
Your intake and exhaust cams are mixed up.
Good luck on both your builds
Future_gohan
haha i know.. Thanks man!
Idahos13
Car: 93 240sx hatchback
Looks good man!
OMSIN
Car: 1993 240sx Coupe SE
I wish I had a shed to build engines in. living in an apartment sucks can't even do an oil change without receiving a "please do not do car work in the complex" letter from the front office.
