project-slow-56k-no-t293052.html
Here is the car:
And now for a change of pace:
The Motor:
Beginning of the test fit process to see what will hit.
Engine on Stand
My little valve man protecting my car from big scary motor.
Here is the 370Z Trans and adapter plate bolted the the motor courtesy of Neo's Garage:
And here is a picture with the ITB's I'll be using.
Here is the clutch and flywheel
Just bought a cheap TIG welder and Plasma cutter
http://www.eastwood.com/ew-tig200-versa-cut-kit.html
For car work it's easily the best bang for the buck. Will weld anything up to a 1/4" and cut up to 3/8". Which is the most I would use it for. Plus it has a 110 converter and our shop currently has no 220 outlets which is another big plus.
So now I'm waiting on the cutter and welder to ship because it's on back order... then I got a lot to do. First thing will be working on a new oil pan and finish adapting the ITB's. No major progress will be made till January though.
