a solid lifter is just that, it's solid, you use shims to set the cam clearance. they are a lot lighter than the hydraulic lifters too.
9k on the std crank, rods, oil pump IMO is a no no.In fact I'd say 9k on the std crank is a no no full stop but if someone wants to try it...
Someone tried 9k before, don't think the pump could cope with it.AFAIK no one does an uprated pump for the CA so I'm guessing a dry sump would be the best way to guarantee good supply.
The crank will begin to flex at those kid of revs too which will knacker the mains and probably other stuff.
I bent a crank revving it to 10k (by accident).
Someone here in the UK is going to be testing jsut how far the std crank can be pushed soon, it won't be pushed further than about 8.5k though I don't think, but it does depend on what rods/pistons you have. The lighter they are the higher you will be able to rev it, less inertia and therefore bending moment.
I'm hoping to rev mine to 8.2k but am dubious as to whether the crank will cope, I will be using stock lifters but with uprated springs and titanium retainers, lightened & hardened crank, ligher pistons and lighter rods.
