Mostdope »
https://forums.nicoclub.com/mostdope-u215213.html
Mon Jan 28, 2013 3:07 pm
Hello, I have a 93 coupe and I'm trying to swap a digital cluster into it. The only problem is the digital cluster I have is for sohc. I've tried cutting the wires and wiring them together and got everything to work except for the tach and the digital speedo. I cut them because the wires going into the black plug are different. The plugs click together but the wires were in different places. The dash harness for the dohc has 11 wires and the digital cluster harness has 12 I believe. Any ideas on what I can do to make it work? Or will the sohc digital cluster not work with a dohc? If you have any questions let me know.
Thanks!
