so this is an example of what to check on the cluster. black is ground and notice how it t's off and goes up? it is the ground for the speedo and fuel gauge which is yellow and black wire which is the ground wire that goes all the way back to the speed sensor. but it also continues to the far left plug to the black ground wire. so if ground is good than go to the next step. red is power. every bulb and screw it touches it powers it. that goes back to the far left plug whitch is the green wire. when looking at the wireing diagram it then goes to a 10 amp fuse located by clutch pedal. this should have 12v with key on and can be checked at the screws as well.
orange that i have in the pic is the fuel meter. that bolt is what you would ground to see if the fuel gauge works.
yellow- is the speedo signal from speed sensor. be aware that the color of the wire is yellow/blue but on the wiring diagram it says y/l.... maybe it means light blue?
green- is the converted signal that the ecu uses. this goes to the yellow/green wire. if you have a tuned ecu with launch control then this wire must be hooked up to ecu speed input.
