Ok. I have 2 240's. Originally, I had planned to have one KA-T powered and the other VQ powered. But now, since I've decided to sell my s14, I've pretty much committed myself to going VQ in my s13.
After thinking it over, to fully build a KA to the way I want it would cost in the range of $3000+. On top of the engine build costs, I would also need about $3000+ of turbo parts. I would want it to start out around 300hp but eventually be able to reliably support 400hp+ and rev around 8000rpm. Of course you can't exclude tuning & miscellaneous costs...
But in comparison, a Rev Up VQ cost in the range of $3000-$3500 on average, right? Then I'd get 306hp (around 260whp, I guess...) at the crank, a nice 6spd transmission and variable timing on both intake and exhaust. Intall kit/costs are looking to be around $1500 when wiring and tuning are added. With bolt-ons and cams, 330hp at the crank doesn't seem out of the question. And it's be proven that the VQ's stock internals should be able to meet my 400 horsepower goals with current turbo technology. Although, I wouldn't be surprised if the boost tolerances increase in the future as support also increases.
The costs for the VQ route decrease if I forego the Rev Up route and opt instead for a FWD VQ. But my question is: Is it really worth it? It seems that for all the stuff you have to hunt down to convert a fwd VQ to operate in the rwd s13, you could spend a little more money on a 350z/G35 motor and save yourself a headache. I'd like to know the approximate cost of using a RWD VQ versus converting a FWD VQ based on this quote:
irax wrote:ok so what is required to do this swap you ask?
FWD VQ engineRWD intake manifoldRWD exhaustRWD upper and lower oil panEngine/dash wiring harness from the VQ car you got the ecu and bcm fromNVIS or NATS with key from the fermentationed car My mounts which use the 300zx motor mounts and trans bushinga drive shaftRWD vq35de transmission revup or non revup doesnt matter just needs to be the same generation of VQ since HR,DE,and VR trans are not interchangeable. RWD waterpipesGreffin RadiatorMy shift linkage kit or the guy from vq240z.com's kit he is selling on hybridz.org. A custom exhaustAn ABS source IE an ABS diff or abs spindle to get a Speed signalDakota Digital Converter to convert ABS pulse into speed pulse. To 'smog' the car or ref it and get it BAR approved you will need the catalytic converters from a RWD plat formSmog equipment from the car you took the ecu/bcm/nats/key fromyou may need an IPDM depending on the ecu you use. You will need to upgrade the fuel pump to a 300zx or Q45 or a walboro 255lhrYou will need an aftermarket FPR preferebly a nismo or aeromotiveyou can use a FPR off of a VQ30 but you will need to modify to fitYou need a DBW gas pedal obviously if you use a DBW VQ ECUthe one from the z33 and the 5.5 gen and 6th gen maxima work
Plus, any other comments/responses to my ramblings would be helpful as I weigh this decision out. I consider the VQ the future for 240 swaps and an excellent alternative to KA-T or SR, but I'm not interested in any RB/LSx/etc suggestions.
Modified by simmode1 at 11:42 AM 3/15/2009
