I don't find that info to be very accurate. N/A is as affordable as you make it. With JWT cams, and a better engine management the KA could make 200CHP with no problems. Of course with the acception of some free mods and a cheap exhaust.brokeAs240sx wrote: N/A will require extensive internal engine work.
I'm talking about whp. There are very few 240 n/a that are making that kind of power. And the ones that are, the costs are usually not under $5k.Bigvinnie wrote:I don't find that info to be very accurate. N/A is as affordable as you make it. With JWT cams, and a better engine management the KA could make 200CHP with no problems. Of course with the acception of some free mods and a cheap exhaust.
d!ck wrote:"being able to hold its own against other cars" is subjective. you need to be more specific. throwing out an arbitrary power level like 200hp and then saying it doesnt matter whether its crank or at the wheels is confusing and makes it that much harder to get an answer...
maybe do some research and get some more solid and clear-cut goals and then ask better questions
Finally, someone whose actually building an n/a ka, haha . I remembered it costs way more than $5k, I just couldn't reference the thread I read (believe it was on FreshAlloy).Ajax wrote:My 240 still under construction will not be making 200 rwhp NA- at least I seriously doubt it. And it is costing more than $5k- if you can do the work itself, you might be able to get parts for around that much... I had to replace a lot of stuff too.
Ok. It's obvious you're new to modifying cars. Trying to jump into internal work when you don't know crap is a bad idea. Start with the basics and build your way up.Silvia_Freak wrote:How hard would it be to make atleast 200hp or more? What would be needed?
Exhaust System (with Test pipe)Underdrive Pulleys.Ground Wire kit.Custom ITB from Suzuki ITB 750cc with custom Pleneum to run FRONT MOUNT COLD AIT INTAKE.Spark PLugs from DENSOSPARK PLUG WIRES from NologyNew BatteryStage 2 Clutch and Fidanza Flywheel.I also already have a Shaved Valves
Also...... I was thinking about doing engine internal work.What is needed for that? What kind of pistons and cams.I was thinking ........from Race Engineering . COmI would by bigger pistons and vavles and have the whole bore and port and polish thing going on. And also a new or used crankshaft balanced and cut.
I hope to have mine dyno'ed early spring after a good break-in (early May, maybe). I think I may get close to this number but who knows...skatanic28 wrote:has anyone even seen an n/a KA putting 185+ to the wheels? i see post after post of capability, just not results. just wondering...
i remember reading about your setup, i think you have a very good chance.its good to see someone actually going through with a build.Ajax wrote:
Are you talking about the air intakes that look like an intercooler? Those are for ricers as they don't actually improve performance.Silvia_Freak wrote:Well.... I dont want to agrue. But I seen in JCW magazine that They have a Front mont intake for a civic.
Yea, we all know front mount intakes exist - we like to refer to them as "interfoolers" - they will actually most likely degrade the performance of your vehicle because of the longer and more bendy intake path as well as risking hydrolock when driving in the rain or through a puddle.Silvia_Freak wrote:Well.... I dont want to agrue. But I seen in JCW magazine that They have a Front mont intake for a civic. http://www.jcwsportcompact.com
Yea I already need new plugs so I was gonna go ahead and jump into that mess. But yea. Whatever info or feedback will help.
Yea about the ITB the reason im doing that way im doing it is becuase i dont want to go the megasquirt route.
You should definately dyno first to see where your car currently stands.A34D4ME wrote:I'm doing the following and planning to ad about 45 CHP.
Header + 2.5" exhaust with no cat = 15 WHP (dyno proven)Nismo Cam = 15 - 20 HP advertised (I buy that)Emanage tune = 10 - 15 HPSynergy of these parts = 5 - 10 HP
My SOHC has 140 CHP plus 45 = 185 CHP. Certainly you could get another 35 HP with 11.0:1 pistons and some good head work.
With 185 at the crank, which should come easy, at least I'll be able to hang with my Jeep Cherokee.
Damn dude, time for a motor swap. Mine has 103,000 miles - the car sat a lot. I think she's up to factory specs. BTW, you're losing a lot in that automatic and those intakes do nothing except look pretty.brokeAs240sx wrote:
I have SOHC (granted automagic, but still) - w/ injen intake, header, hi-flow cat, exhaust (2.5" system throughout), UR underdrive pulley, about 160k-170k mi, pulled a whopping 97.4 whp on the dyno.
Might have been 140chp back in 89, but it has been 16 years - and fuel injected cars don't usually hold up that well unless you just did a complete rebuild.
And measuring power by the crank is all guessing - it's all about the whp.
That's like claiming an exhaust does nothing except look pretty. Why do people fail to understand that in order for your engine can only pump as much air out the exhaust as it draws in through the intake? Oy.A34D4ME wrote: those intakes do nothing except look pretty.
I think his next mod is to let X to the Z drop in an 'Engine Dressup Kit'. That's worth at LEAST 50HP... Maybe more...thekage wrote:brokeas... sounds like your next mod should be a Full rebuild and a 5spd swap
