duncan351 wrote:I"m not calling out any names but I will say that there are a chit load of KA-Ts on this forum and others that are straight half ***'n your setups. Then you get pissed when it blows. Look, save your money and either buy a real kit or make a good "Complete" kit. There are some places you can cut corners but there aren't many. I look at some of these pictures of these kits and you're daily driving on these cars. I'm thinking to myself how long do you possibly think that POS will last? Most of you guys cars I'd blow up in 2hours. If your car can't with stand 3-4 hours of hard obuse then chances are pretty great the dam thing isn't gonna last(at lower power levels)
Save your money and wait til you have a good solid kit before slaping any kind of turbo on your car. Do some real research too before choosing a turbo. This chit started when SSA came out with that BS manifold & that sorry POS T25 Turbo kit. Now every week I read on a forum somewhere some asking about A T25 or T28 working on a KA. The KA is a 2.4L 9.5:1 compression motor. Your choking the dam thing up with these little turbo's just making a bunch of heat. That told the true about how many folks copped out and just wanted a turbo on their car instead of wanting a fast car because your car still isn't fast with little turbo like these.
I hope you're not referring to my setup?!? If so, it's not helping at all...
When I initially turbocharged my car, there were very few options except for the $4000 kits from Nsport, FMAX, and XS engineering...BD, IAP, Phat KA-T, GReddy all did NOT exist at the time. The KA-T forum did not exist either. At first my set up was terrible, but it was a learning experience and I wasn't running much boost and I knew it wasn't solid, so I continually upgraded as funds came in...
I have not cut a single corner with my existing set-up except for the rods, and everyone keeps asking why I chose to use the stock rods, and it's beginning to piss me off...both me and Fiznat were under the impression, from the testimonies of people on forums like THESE, that they were PLENTY STRONG for up to 500 whp. I'm not trying to blame any one for giving such advice, but honestly, there's so much hearsay and bench-racing on these forums. A lot of people who post here don't even have KA-Ts. I was only planning on making 330...well within the "limit" of the rod. I listened to the advice I got and it turns out the advice was incorrect. Live and learn. I thought the $750 would be better spent on upgrading my fuel rail/injectors/MAFS. I thought I had all my bases covered---I went overboard with the build replacing stuff that didn't need replacing just because I wanted to make sure it was bullet proof (eg, ARP head/main studs, ferrea valves, new valve seals, springs, seats, retainers, oil pump, water pump, thermostat, timing chain, tensioners, etc). Little did I know that the one thing I did NOT upgrade was the weak link. Now we know.
And yes, my turbo is small, but not for the type of driving I do (daily driving, and I much prefer throttle response and torque down low to high power up top). It's certainly not a heat pump though (if it is, it NEVER gets my air intake temperatures much past ambient temps). Not to mention, water temp was 178 degrees...that's pretty damn cold for a 90 degree day. The turbo's being too small had absolutely NOTHING to do with the rods failing.
I agree with you that there are many crappy set-ups out there that have cut corners, but I do not believe mine can be considered one of them. My engine did not blow up due to me cutting corners, which is why it's so damn disappointing. It blew because no one knew how weak these rods really were.
Regarding what I'm going to do with the whole project...I've had the car for 3 years and I've loved it since day one. It's my first car, and I've spent hundreds (probably thousands) of hours modifying it and working on it. I've learned so much along the way. The car handles and looks phenomenal....it's without a doubt the best handling car I've ever been in. If it turns out that I just need a new block, and say, one piston (do they even sell one piston?), then I'll most likely re-build it, because someone on here already generously offered me a block for free. If it turns out all of the pistons are fried and my head is completely gone too, then I may scrap the thing altogether, put in a stock KA, part out all the turbo parts, and sell it, possibly for a Miata (yeah it's girly, but it's one of the best handling cars in the world), or maybe an E30 M3.
I plan on tearing apart the engine soon, I'll have pics, etc when I do that.
