toadx8u »
https://forums.nicoclub.com/toadx8u-u29885.html
Tue Sep 01, 2009 5:12 pm
yup tis is gonna be for the RBXX that im building for the drag chassis i have...
about the turbo...specs = just BIG...lol like dont get too close BIGHolset HX55comp turbine 2.835" 3.031"72mm 77mm
holset wont release their trims but when i get home for mid-tour ill break out the mic set and calculate them...and from the pics i have i cant tell what the turbine is rated...but its either 16, 18 or 22cm^2, converted over those are .92a/r, 104a/r, and a 127 a/r
the compressor flows .75kg/s or 99 lb/min which is just over 1400cfm lets see holley make a carb that big...
just to compare...the GT3076R on my street car flows only 53 lbs/min or 756cfm and took my stock block RB25 to 11.6 so far...
