Alright guys, I think I finally have a semi worthy update for ya'll
Since the last update I moved down here as to have more time to invest into getting this thing running. I guess first I'll start with the negative:
So yesterday I had a little oopsies. The new house has 3 car garage with a 2 car part and a smaller single car part(it's all open inside). Naturally, the little one is mine. As I was pulling in it looked like I was clear but the corner of the front bumper caught the edge. I haven't actually tried buffing it, just rubbed at it with a sponge. Not horrible, but it's enough to leave a bad taste in my mouth:
Now that that's taken care of, lets move on to the actual update.
In June I ordered my pre-made harness from Wiring Specialties. I received it in mid July. Sadly, I got no pictures of it as I was too anxious to install it. I'll go ahead and say that the quality is top notch. Install literally took 30 minutes. It makes it much easier routing it through the firewall and not having to worry about wires breaking when bending them.
Couple of pictures showing the harness and also showing the current state of the bay:
You'll notice that it's running recirculated now. Went ahead and ran that setup to ensure that the problems weren't arising from being vented. It wasn't, but I won't argue with better gas mileage.
Before the harness, I'm sure you'll remember, the car was running super rich. I would foul spark plugs to the point that the car wouldn't start within a week. When I got the harness I went ahead and bought new plugs, and when I started it for the first time with the new harness it started up great. Smoke was no longer coming from the exhaust and it idled perfectly. It still hesitated, but only if I opened the throttle more than 1/4 of the way. Also, when holding a steady rpm, it wasn't shaking anymore. It ran fine for just cruising around, but was in no shape to get on it if I needed to pass people. Unfortunately, my tach still doesn't work. I thought it had to do with the wiring but apparently not. I guess that shop I took it to somehow fried it as it was working before I took it to them.In the past week and a half I've driven it about 300 miles with no problems. Just cruising around. I drove the first few days with no power steering and decided that wasn't going to work for me, so I started focusing on that. You'll notice in the pics above that the power steering reservoir isn't on the shock tower. I decided to relocate it. Also, note the beautiful new coolant overflow
I routed the hoses through here:
and up directly under the resi. The cut isn't the cleanest, but lined with rubber edging to avoid leaks from the hoses rubbing against the metal:
Now, some might be wondering how well it works since the pump likes to be gravity fed. I haven't had any problems. Power steering works fine and the new ss line is no longer leaking. I know the monster can is ghetto fab but I kept it has amateur as I could with a proper bracket instead of just zip tying it in place. Same with the power steering reservoir. Hopefully I don't receive too much hate for it.
Next, some of you might remember the gaping whole for my cold pipe. The initial hole I had cut was way off, and I ended up with this:
Since I can't weld, and i don't know anyone down here who can teach me, I did the best I could with it. I cut a piece of cardboard down into the initial shape I wanted and traced it out on a 1/4" sheet of aluminum. As I said before, I can't weld, so I screwed it in and painted over the screws. Much better imo:
Again, I put rubber edging around the cold pipe and wiring harness.
Now for the biggest progress. After thinking it over while on the toilet(when I do my deepest thinking) I came to the conclusion that my TPS might be off. It made since since the engine was smooth at any rpm as long as I didn't open the throttle past a certain point. So tonight I went out and checked it, and with the throttle closed it was at .32 volts
. Adjusted it back to .45. Started it up, opened the throttle and no hesitation. Took it down the road, and it opened up just fine, but the turbo was pulsing, for lack of a better word. Pulled over a couple of times and messed with my boost controller and eventually got it to boost up to 7psi smoothly. It felt great! Up until now the highest I could get it was 2lbs. The only thing now is that it's still skipping in the lower rpm range, but then clears up and goes. EXACTLY like before. I have a sneaking suspicion that the problem lies in the battery or alternator, since my battery and brake light are on, and my gauges keep shutting down, also exactly like before. So tomorrow I'm going to have them checked, and then monday I'm going to look into finally having my bov welded to the hot pipe.
Since it's now the hottest part of the summer, I finally decided to order my A/C brackets from CodyAce. That'll be a blessing. sometime this week I'm going to hit up the junkyards in search of a g20 throttle body with a second cruise control cable bracket. If you don't know, the g20 throttle body is 10mm(I believe( larger than the stock s14 sr20 throttle body. So when all is said and done this will be a fully functioning swap with all the bells and whistles. I'm also going to look into having the intercooler piping re-polished. I think that will be a nice touch.
Other than that, I'm going to repaint the valve cover as it looks like a** and also repaint my calipers with a different color combo. Not gonna ruin the surprise on the colors I have chosen.
Stay tuned!
