Vac delete and weber carb install vac lines how it should be!!!!
made a mistake on my install thought I'd post this up so yall would have an easier time than I did with it.
vac lines from carb. the top fitting is your vapor outlet 1/4 id tubing but you can get by with 5/16th ( i just use fuel lines. I ran it into the rail then out the other side to the purge on the charcoal canister.
the bottom line is vac advance for the dizzy it connects to the port next to the mixture screw. ran it into the rail then t'd it after the rail one line to the dizzy one to the vac from diz port on the charcoal canister, and thats it for lines from the carb minus fuel.
lines from carb to rail.
the outet of the rail under the exhaust side near the dizzy
where I T'd the vac advance line one goes to dizzy the other to vac on the charcoal cannister
this is the charcoal cannister and the connections
just used vac plugs to plug the unused vac stuff on the intake. going to get some 1/4 inch npt plugs (plumbing stuff) and close those ports eventually.
here's my fuel pressure gauge, it is a spectre from auto zone I think it was like 15 bucks. I made a custom T from plumbing stuff (brass) all 1/8 inch npt threads with 5/16th inch hose barbs. cause the mr gasket pressure gauge I got from advanced didn't come with a T, but that gauge sucks the first one didn't work at all and the second one I got didn't work worth a crap either. Stay away from them. The spectre fuel pressure gauge comes with a plastic T that will work fine, I just figured sine I already put $20 into this brass T by god I was going to use it.
I was using a spectre fuel pressure regulator but it crapped out on me in 15 minutes (while I was going down the road) cut fuel off completely. didn't need it anyway with the return lines bypassed I get solid 3 psi off my pump (no surging or anything its perfect) I hear carter makes an Ideal pump for those of you that need to replace the one you have and are thinking of going to a weber.
here is my fuel return line delete. I moved the fuel inlet on the carb to the left side away from the engine. (heat makes gas vaporise in the line). I installed the fuel filter right at the fuel supply rail outlet then hosed up to the pressure gauge then finally to the carb. I did have the regulator between the filter and the gauge. I have the fuel return rail capped with a vac plug just to keep dirt out of it.
egr valve was delete and capped no smog here
finally my amp and sub box I have the subs facing away so the seats will recline. I take a picture next time I pull them out they are kenwood 12's x2
hope this helps future inexperienced carb installers! or vac line deletion enthusiasts.
