Alright Valve adjustment with some pics. It can be stickied and posted in the DIY if y'all want.
parts needed.
27mm Socket
1/2" breaker bar
.30mm feeler gauge
screwdrivers
and I think 7mm wrench can't remember or crescent wrench works.
recommend a new gasket set (12bucks at your preferred parts store)
now I didn't remove the fan or the fan drive belt doing either would have made turning the crank easier (something to keep in mind. I unscrewed the fan shroud to give my breaker bar clearance and kind of fought with the fan.
1st step run engine to operating temperature.
2nd step remove valve cover via 8 valve cover retaining screws
3rd step remove distributor cap. (not necessary if you can read the cam lobes)
4th step align hash mark on crank pully to 0deg timing reference mark
kind of hard to see the hash mark on the crank pully. it's just east of my feeler gauge.
5th step confirm which cylinder is TDC (top dead center) Will be either 1 or 4
you can tell via the position of the rotor in reference to the dizzy cap or by reading the lobes on the cam (if 1st is TDC both the lobes on the valves for the first cylinder will be out of sight (down) the valves will be seated. If not then the 4th piston in TDC.
IF 1st piston is TDC you can check clearance of 1intake 1exhaust 2intake and 3exhaust
IF 4th Piston is TDC you can check 2 exhaust 3 intake 4 intake and 4 exhaust
Here's where you check the clearance and what it looks like in there
the whole kit and caboodle cylinders are 1 2 3 4 from front to back left side intake right side exhaust.
to adjust valve clearance loosen jam nut with wrench and use screw driver to adjust to proper height. there should be a slight drag on the feeler gauge when the gap is correct. while retaining adjustment screw in place re-tighten jam nut. check clearance one more time.
to go between 1st piston TDC and 4th piston TDC requires one full revolution of crank via 27mm socket and breaker bar. that notch on the crank pully will come all the way around to the 0deg reference mark.
once adjustment has been completed reinstall opposite of removal and happy truckin!
Here's a picture of a cam lobe. the way it works cam load presses on rocker arm which opens that valve. so you want to check the valves with them shut ie the cam lobe not pressing on the rocker arm.
also a good time to go ahead and paint the valve cover that color you've always wanted it to be
