Here Comes The BOOM!!!!!
Post all your Nissan electronics, car audio and stereo questions here!
hotcakes0007
Car: 2002 Lexus Is300
:D here comes the BOOM!!!
Started cleaning the ****
Then Paint
Amp's
Box
Beta Finish
Sub Box Wraped
Mids Highs
My Headunit
Modified by hotcakes0007 at 10:35 PM 1/10/2008
two4dsxtuner
Car: 1992 nissan 240sx
dont u think that piece of wood is too big, it like kills the trunk, other than that, it looks like it hits hard though, two amps! daym man
NickyD240
Car: 1993 Nissan 240SX SE
Aren't those amps going to overheat with no ventalation?
hotcakes0007
two4dsxtuner wrote:dont u think that piece of wood is too big, it like kills the trunk, other than that, it looks like it hits hard though, two amps! daym man
Dude the wood is made for a wall im going to put carpet and plexyglass to show off amps. i made it look like a wall and keep some of my trunk.
hotcakes0007
No there not most amps are made to handle worse
NickyD240 wrote:Aren't those amps going to overheat with no ventalation?
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Great idea and execution!
I'll have to see if i cant do this for my MTX 9500.
I hate moving that thing tho, its a freakin beast
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Were you rear ended? The floor looks a little banged up in the left corner.
But good install so far. And good choice on the amps
hotcakes0007
Not gona lie it probally was by old owner but that was also my doing with the MASSIVE HAMMER i used to take off the spare tirewell
Modified by hotcakes0007 at 9:52 PM 1/6/2008
keith0486
cough cough get a 1000/1 for the sub sounds soo nice my buddy has one its loud as hell.
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
Thats a nice clean setup. What are you gonna wrap that box up with?
mchkc240
Car: 91,92 Nissan S13 - SOLD
98 BMW E36 - Running
I like your beat box
that's some gangsta sh*t
GIJOE69
Car: Going Side Ways!
wow the amps cost more than the car haha!...you ever thought about how you gonna use a rear strut bar? ?
hotcakes0007
ROFL LMAO True actually my sub and old high output gl box is more than my car :D not useing bar
Tsukiko
Car: 1990 240sx fastback KA24E
Seems to me that sub is underpowered with that amp, seeing as most amps marked 500/1 or something to that effect put out about 500 peak, not RMS (which is what you should be paying attention to), at something around 2ohms of resistance. I hope you have dual voice coils on that sub or that its resistance is naturally 2ohms. I personally dont like the sound of a 2ohm load though. Its a little dirty (used mostly for pure SPL), whereas 4ohms is pretty sweet sounding. Someone mentioned a 1000/1 rated amp. Kudos to that guy.
hey how about you post the specs of your sub and amp? what are you running for speakers in the factory locations, if any? any plans for acoustic treatment?
also- is that sub designed for a sealed enclosure? Im a huge fan of building a sub box to factory specs and calculating the port and tube size. The diameter of the port determines the frequency it accentuates, and the length of the tube behind it determines how much it is accentuated. then of course you get into the frequency response curves of the sub, amp, and deck....
sorry im an audio engineer... lol
s14tan
^dude....build me a box, have a feeling it would be kick as$ lol
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
JL amps are reated in RMS not peak, and they are rated at constant power output at 9-15 volts.
hotcakes0007
Lol belive you me the sub is far from underpowered box is sealed since i dont have the space for a ported box ill get full specs up in a little bit.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Looks alright, just dont get a flat tire.
eazye2000
Car: S13 KA-DET
OutToWinPAHC wrote:JL amps are reated in RMS not peak, and they are rated at constant power output at 9-15 volts.
I'm going to say that it IS a true 500 watts RMS at 14.4 volts. The only amps that I ever remember being a 'true' wattage at 12volts are the old Earthquake amps. And maybe the old skool' Sound Stream.
I'm not going to get into a debate on this forum. Head over to the audio/video part if you want some 'technical' advice.
All-in-all, Looks like it's going to be a clean install, OP.
CMG
Car: 1989 240sx Hatch w/ Redtop
I don't know nothing about JL amps, but I've never seen an amp that has RMS watts in big writing. It's always Max. in big writing, then RMS written small somewhere else or on the bottom. Hope the op has some horsepower on his car, that audio set up would kill a stock ka24e.
Tsukiko
I'd say hes on the verge of needing an alt. I would also recommend a capacitor for the sub amp, since its not the only amp drawing power and needs a "buffer"
I was recently running an amp that was rated 1200 watts peak at 1ohm... although i ran it at 2ohm, about 800 rms, two 10" subs... everything seemed just fine until i added a second amp for a pair of 6x9s. then i could tell i needed an alt, and only cause the subs started to get boggy.
hotcakes0007
CMG wrote:I don't know nothing about JL amps, but I've never seen an amp that has RMS watts in big writing. It's always Max. in big writing, then RMS written small somewhere else or on the bottom. Hope the op has some horsepower on his car, that audio set up would kill a stock ka24e.
Yes sr20 is going in march :D JL audio can run at any impedence level. So 4 ohms or 2 ohms u can get the true rms which in my case is 500 Watts
Tsukiko
s14tan wrote:^dude....build me a box, have a feeling it would be kick as$ lol
haha i would love to, since i havent been able to put all the theory into practice as of yet. But seeing that you're in texas, and im in california...
and if i remember correctly, the W7 JLs are rated at 1000 watts, right?
SPECS!!!!
too bad you dont have a hatch, (at least when it comes to audio) it makes subs sound amazing.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You need to work on your math a bit RMS ( Rout mean square) is the effective ,voltage which is 70.7 % of peak. RMS the longest part of the waveform. That RMS voltage dived by the impedance of the speaker gives you the current then you take that current and multiply by the RMS voltage and you get your power aka watts.
So if your AMP is rated 1200 watts peak at 1 ohm the RMS power also true to 70.7% would be 848 watts RMS. Now double your resistance and that number is decreased by 50%. Simple Ohms law. So your true RMS power was in the range of 424 watts.
But depending on your wiring to the coils that power could be spread differently across the coils and the effective power could be something else.
I am a degreed electronics engineer and it’s a shame because a lot of people are lied to at the store and really think they have more then they really have.
Now when it comes to capacitors the 1, 2, 3 and 15 farad caps they sell are a miss interpretation of the true number. There is also a formula for determining the capacitance as well. In this formula time is a factor. These audio companies take this formula and manipulate it. The discharge rate of the capacitor simulates that of a rear 1 farad capacitor, but only for a nanosecond. Somehow they get away with claiming it’s a one farad capacitor. An actual 1 farad DC cap would be as large as the car and 1000’s of pounds.
DC capacitors in cars also tend to wear out rather fast due to the AC waveform caused by the alternator. Usually they don’t make more then 2 years.
gripstr
Car: Street Legal s13
Nice i have the same exact setup on the s13
CMG
So are you saying all caps are worthless? What about for low wattage uses? Back in the day I found a cap at a military surplus store, and it stopped my lights from dimming from the power draw, but that was maybe a couple hundred watts.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Well they help, but the arent a true farad or higher. The store energy and when needed they discharge it. DC caps have a 3 year shelf life and a normal 7-10 in circuit life. The harder they work, they harder they wear out.
A cap on any car, system or no system would benifit from a cap, but plan on replacing it time to time.
The most important thing is to have a hormonic and supression filter. If I had the means to build my own ciruit boards I would build something for resale.
Tulsa_S-13
Car: 1991 SR 240sx
OutToWinPAHC wrote:If I had the means to build my own ciruit boards I would build something for resale.
You could probably build your own active low-pass filter fairly easily, although the only problem to worry about would be how well it effectively eliminates the remaining harmonic distortions.
Tsukiko
ugh good point...
i'll have to brush up on my ohm's law and such, i hated studio maintenance class. lol.
snoboard1500
Simply sick
