Joe »
https://forums.nicoclub.com/joe-u4941.html
Sat Nov 25, 2006 8:44 am
Ok checked tps. This is where it gets strange
Engine was origionally an automatic.
I have 2 plugs. Grey and brown. Grey is the top one, brown is the bottom.
Grey plug has no power or ground.
Brown plug has power, ground, and appropriate signal voltages. (5v, .3 -4v at wot, and ground.)
I was always under the assumption the grey one was for the ecu brown for the auto trans.
Plugs are different sizes by about 3mm (thanks nissan. ***holes) so I'm gonna splice them together and see what happens....
Ect checked out normal. Has good resistance across it and supply voltage.
