Awesome, thanks for the confirm!240z4u wrote:300+
Yes you can use that MAF. I have one on my S2 motor. Works fine.
I too am maxing out my MAF at some points. Its not totally consistent. I think its a turbulence problem under boost. I am also blowing through mine.
I know I am not making enough HP to max out my MAF but still do sometimes. Then of course, it runs super rich and like poo.
Keep us updated, because I am wondering if this is a symptom of my maf location. I am assuming you pretty much have your car tuned, I have heard its pretty normal to run richer with the blow through setup.
Evan
My friends went out in his RB25 before and the car ran fine. It just didn't make any power up top. Something to check out if you have any other RB friends.Kamin wrote:I had my cas go out about a year ago, this feels NOTHING like that...I don't think I'm gonna be able to source one before sunday....
Awesome to hear from a trusted source. I can tell by looking at the data logging graph that I am having the issue as the MAF is maxed for a sec or two. so the maf might not be bad. But I was under the impression the MAF would be good for 320hp as blow through or the stock setup.... I doubt I'm pushing 320hp at 12psi (stock turbo).Carl H wrote:when maf voltage hits 4.1v for more than 3 sec the ecu will hit the boost limter and will dump mad fuel...that being said a maf that has taken a **** will also cause it do dump fuel.
well thats true. This is what makes me think the MAF is damaged because I shouldn't be pushing 320hp at 3900 rpms... (I wish)Carl H wrote:blowthru or drawthru you'll still see the same ammount of air, only way around this is to either rechip (stupid expensive) or get a pfc.
Yea I don't think its ignition either... something is telling me its some senor making the ECU dump fuel. I hope to have a big update this week , going to try a new maf and a few other tricks.S12_hybrid wrote:It doesnt sound ignition related, as it would normally just bog under power with bad plugs, or coils.. It really sounds like a leak (I know you've tested the pre-manifold stuff).
But try this: Grab a butane torch, and with the car running poke it in and around the intake manifold runners (near the gasket) and the IAC valve, and anywhere there would be a potention crack. And if the idle rises, you've found your leak. note: DO NOT LIGHT THE TORCH!
-Dan
Yeah, thats a good trickI've done it with a cigarette, just blow the smoke where you think it is and see if it gets sucked up.S12_hybrid wrote:It doesnt sound ignition related, as it would normally just bog under power with bad plugs, or coils.. It really sounds like a leak (I know you've tested the pre-manifold stuff).
-Dan
Hey let me know if this works out or not, i am having the exact same problem with mine right now and we both have the same mods except mine is a 20 (q45 TB/ 3"cold/ 2.5" hot/ RBTally intake manifold/ stock turbo/ RB20) i am running 12 psi as well and it acts like it is some how sensor related, i have a friend that has a 20 locally but his has a z32 maf so i cant switch mafs with his, but we have switched just about everything else and still it does the same thing...300Plus wrote:I'm pretty sure I have some how damaged my MAF to the point where it reads but maxes out sooner then it should. Check the ground wire to your maf.
Still working on picking up the new MAF for mine to see if that was the problem
Well I went throw the obvious boost leak areas and felt around every coupler but it hit me lastnight that the hose I have running under the intake mani that goes to the IACV may have a leak...rcrdps wrote:Your slopes are all nice and smooth. No spikes like a faulty sensor. Looks like it could be more of a boost leak.
Where is your BOV? Is it operating as a blow off, or as a bypass?
Then again, maybe you really are maxing your MAF. You nearly doubled your boost, and with that high flow manifold,......
Gene
