rcrdps »
https://forums.nicoclub.com/rcrdps-u42394.html
Sun Dec 24, 2006 10:43 am
Narrowband O2 is supposed to bounce when in closed loop. He was keeping the RPM steady, so it was in closed loop. Then he floored it, and it went rich. Then he let off the throttle, so it went lean because it was coasting. All you get with narrowband is bascially on and off. Rich or lean.
The ignition is kinda interesting unless you slowly came on the throttle. Your first graphs up top look more like it. The timing should drop off the face of the earth when you floor it. I'm guessing on this lower graph, you kinda got on it, then floored it. After the MAF problem, you started letting off. That's when it spiked back up. Your timing map reduces timing the more you floor it, so as you let back off, timing is added back. Hence the spike back up.
You said your wideband pegs rich, and your MAF pegs. You are definitely maxing your MAF, and it's reacting properly to that. Now the reason you're maxing your MAF,...????? It's too small,.... boost leak,....turbulence as you stated,.....?????
Gene
