Help NISTECH...Bunch of trouble codes.
NISTECH
sw/v and tp/sw just turn the key on engine off, and push your gas pedal to the floor the release it if the fuse didnt blow thats not it. the sw/v(swirl control valve) will also change under hard throttle. have you checked the connector for moisture or corrosion in your right kick panel yet. thats is a very important starting point. key off, unplug it and look inside the terminal area.
Camel
Car: That would be obvious....
I will do both of these tests this weekend. thanks for all your help. if you want those fsm's, i will make a cd and ship it to you, my treat. it is the least i can do for all of your help.
Camel
tp/sw ok, tried that this afternoon. i will check m63 this weekend.
NISTECH
yea I would take it hit up by email and I'll give you a mailing address. I appreciate it. [email protected]
Camel
CD is on it's way. Should take 3-4 days, parcel post. Sorry but I cheaped out. I haven't blown a fuse yet and i haven't checked my connector yet. My car all of a sudden started running like a scalded dog the other morning and has continued to do so since. I figure that it went into ready mode and put in a better fuel map instead of a safe mode one. Can you verify that? I would love to go ahead and get my emissions done if it is ready to go.
NISTECH
have them check your moniters see if they have completed and no codes got stored. if its all good run a test. Dont sweat the shipping method it was generous of you to offer it to me. thanks again.
Scott
Camel
so just tell the emissions guy to check the monitors and see if there are any codes and if not, go ahead with the emissions test?
Does this thing actually change maps when it hasn't gone into ready mode? Like a safe mode kind of thing?
The performance difference is quite obvious.
There is a copy of the newest acrobat reader on the disk. for the best performance on the documents since they are quite large, install the new reader and copy the documents to your hard drive. the fwd.pdf file in each folder is your quick reference section to link to all the others. the table of contents rocks on this set of books. you will have a lot of info at your fingertips now. but the most important is the 98 fsm, of course......hehehe...
NISTECH
yes have him make sure your moniters have completed. That is the main OBDII difference from OBD I if they plug into your computer for the emissions test that is what they are looking for. I dont know how many they require to have completed to pass a emissions test but here its all but 2 of them have to have completed. If they have completed and there are no codes stored tell him/her to run the test. Yes there are 2 modes of operation with the computer control of your car..normal control and fail safe. Fail safe your car would lack power most noticably. they will go into fail safe only for a small hand full of reasons. If your car appears to be running good I think your ok.
Camel
would it go into fail safe if 12 different sensors went bad at one time? I.e. the fuse blew that powered them.... i am thinking that actually happened, and now it has recovered.
NISTECH
yes if the sensors are part of fuel or spark control. Primary sensors for those 2 functions are what send the car into fail safe mode. Once all repairs are done it will relearn all values and trim fuel and adjust spark advance to the correct drivability conditions.
Camel
How long does the re-learn process take? Is it variable?
NISTECH
it usually occurs within 5mins of driving after a warm up cycle. but yes it can be variable.
Turb0wned
do whatever u can to avoid a dealership there gonna give u a really high price
NISTECH
DUDE I work for a dealeship!!! How much do you think I charged him for helping him out? Our shops are not run down ****holes with inexperianced mechanics fondeling cars and throwing parts at cars till the customers pocket is empty and hoping something fixes it. sheesh.
:beatfreak
Camel
Actually, my dealership was very forthcoming about not being able to find the problem immediately. Props to Sutherlin Nissan at the Mall of Georgia.
The car passed emissions today. So I am going ahead with my header and new cat arrangement soon. Just got to order the cat and the gaskets.
If the fuse blows again, I will take note of the conditions under which the fuse blew and check M63 at that time. Otherwise, I am just going to drive the car normally. I may get one of those cool lighted smart fuses to put in that slot for easy recognition of a blown fuse.
NISTECH thanks for all your help, your cd should be there soon. I may ask you some more about this if that fuse blows again.
NISTECH
sweet glad to hear it made it through..just hit me up when something else pops up. Thanx again for the CD
Camel
Will do, let me know when the cd gets there. just want to make sure you get it.
NISTECH
will do.
NISTECH
got it today. thanx chadd appreciate it. I havent loaded it yet. gonna load it up on my other computer. its newer and has more space for it.
Camel
Not a problem, easier for you to help me out now...hehe but you knew that was coming...
just load the acrobat reader first, then copy all the folders to a location on your drive. and you are in business man....enjoy
Camel
Did you load it up and take a look? Should be the exact thing you have at work...
NISTECH
no my other personallity usually handles that program stuff but he's become lazy lately...lol
I will load it soon just gotta take a few mins to do it. I havent been at the computer much the last couple days Really havent had time. tonight is the first time I have really had time to sit down at it for a couple hours.
NISTECH
Chadd you rock bro...didnt work on my other comp for some reason it wouldnt read the disk. but its up on this one.. It is exactly as it is layed out on the factory ESM's I really like the quick link menu on the left.. it makes it so much easier.
Camel
that new version of acrobat is great for those manuals. Glad you like it. Hope you find it useful when i bother you with more questions.
NISTECH
I didnt have to upload the acrobat you send I already have the current version on this computer. I would of had to on the other if it would have recognized the disk.
Camel
Ok so check this out. I have been talking to the original owner of the vehicle and here is a portion of the email:
Never did get the truck fixed but I did get a 350ci for it but its just sitting there waiting to go in. and lately I'v been looking for a new car more than likely a protage 5 but we'll see what happens with that. And on that o2 problem not to sure personaly but Reagal nissan did the work on it and oridganaly that was what they told me the problem was but then they said there was something wrong with the computer causing a short. They told me that they had replaced the computer but thats all I know about it. ttyl Stephen
Chadd Hall <[email protected]> wrote:Definitely man. I wanted to ask you about your experience with the Nissan dealership and the o2 sensor. It seems that it wasn’t actually the problem and there is a intermittent electrical issue on the same circuit as the o2 sensor that causes the fuse to blow and then the car starts throwing codes. Interesting stuff, I have been trouble shooting it for a while now. Other than that, I absolutely love it.
So what do you think? Talk to the dealership that worked on it? Get the service records?
NISTECH
no no need to take it back I honestly dont think its the ECM or it would blow the fuse all the time.. after you played with the harness the fuse stopped blowing so I really believe its a harness issue. Getting the service records though is not a bad idea its always nice to know the history of the car.
Is your car blowing the fuse again?
Camel
Has not blown since the day after the dealer. However i have not recreated one condition in which it blew. Extreme decel. I have done 15-110mph in one shot with 5700 rpm shifts but i braked down instead of downshifting. the last time i down shifted that hard, the fuse popped.
Camel
Started blowing the fuse again on a 1000 mile trip to the Outer Banks of NC. I guess that i need to start following the diagnostic path again. First step is checking m63. I never did do that before.
NISTECH
Well let me know what you find I am still floatin around here..lol
