mdb4879 »
https://forums.nicoclub.com/mdb4879-u186863.html
Thu Apr 26, 2012 2:18 pm
Hey Casey, fancy seeing you here, lol. Ok, so first off, are you sure you're at 10psi? I remember you had that Harbor Freight boost gauge and it may not be accurate. Reason I ask is I have some cheap Glowshift gauges in my Pulsar and I use to think I was running 10psi until one day with the car off I realized the needle sat about 2psi below zero. So I'm actually running around 12psi. Idk if there's really much difference here, but you saw my exhaust and it's pretty free-flowing (turbo elbow then a 2in. long pipe) compared to yours I would think (at this power level, though, there may not be much difference for reall). Plus, my wastegate actuator is probably really worn so even without a boost controller I'm running quite a bit more than the stock 7psi. You may have the opposite going on. A (possibly) more restrictive exhaust and a much fresher turbo and actuator. So you may be running 7psi, but idk. that's just a guess.
Also, idk if it makes much difference for drift speed, but your car still has full interior. So it should weigh, what, 2700lbs? My car is completely gutted, not even a dash, and weighs 2300lbs. That being said, with the (possible) power and weight differences between your car and mine, including my really low gearing (75mph in 5th = just over 4k rpm), I'm only fast enough to stay even with a stock G35 coupe up till a little over 100mph. So I can only imagine your car couldn't be too fast (if it's only running 7psi rather than the 10psi your gauge reads.
I doubt the S15 BB turbo is out of it's efficiency range, at least not by much. And it should spool fairly quick. My stock t25 makes full boost at 2800rpm. I'm guessing yours can make it at a few hundred more than that. 10psi is 10psi, no matter the turbo. a GT30 can make more power at 10psi than my T25 because it can flow more, but it won't make more torque in the mid range unless mine is out of it's efficiency range and is making the air hotter. All turbos will make the same power at the same boost on the same motor if the intake temp is the same and the motor isn't choking out the turbo. If the MAP is 10psi at 7200rpm with a T28, it's making the same power as the T3, provided all other variables are the same. The reason they say you only get 10whp more from 14psi vs. 10psi on the stock T25 is because in the top end (where hp is made) you aren't really getting 14psi. The compressor is choking out and making less boost and the air is hotter (less dense). There will be far more midrange torque, but about the same top end power. So in other words your T28 will pull just as hard in the mid range as the T25 if they're making the same boost, and even harder in the top where the T25 chokes. (Sorry, I've always wanted to give that explanation about why and when a larger turbo makes more power, but sometimes the same power. It's like a hose on an air compressor. No matter how big the tank (turbo) is, only so much air can be forced through the hose (motor) until a bigger hose (via cams, port work, displacement) is installed)
If you had boost leaks I think your car would run like crap under boost. When I first got mine running I had a few boost leaks to take care of and until then it'd run terrible under boost. This was because the MAF had already metered the air, but it wasn't reaching the motor. The gas was being poured in like the air was there, though, causing it to run REALLY rich. I too tried disconnecting my wastegate line once and it did the same as yours. Built boost then cut out at 14psi.
Now on to making more power. That turbo should be pretty well suited to your application. It'll spool quick and should make enough power for you needs (I'm guessing around 280-300 crank). The MAF and injectors will max out long before that, though. Most of the steps for more power have already been done it seems. So all you need now is more fuel. A larger MAF (I would think an RB or a Z32 should do the trick) and larger injectors (DSM 450s if you're on the cheap) and some way to tune it. I know most on here are against SAFC, as am I, but it's an option. You can ask Kyle what he thinks of it. I know he used it back when he had his SR T25 on. I don't know much of what's out there, but I'm planning on Nistune for mine when I get around to it. You'll also need a bigger fuel pump and a FPR (if you don't already have them that is).
I think that's basically it. If anyone feels my explanation about the bigger turbo thing is inaccurate, please say so as I may be wrong. That's just how I've always understood it.
