Well, we've got a real mess here. My stepdad pulled the motor this morning and got it taken apart:
Here is why we had low compression. the ring gaps were lined up on the number 3 and 4 cyclinders.
3
4
That's the least of our worries at this point. Here are some shots of the rod and main journals:
It may be kinda hard to see in the pictures, but they're really rough. Not like a "something got in there and scored them" rough, but a "the machine shop cut the crank, and never polished it" rough. You can tell that's what happened be cause usually if particles did it, then one end we look alright, but it'll get worse the further back into the motor you go, but they all look the same.
Here's a couple of some of the rod bearings:
The top bearings, the ones with load on them, are already worn down to the copper. There's no way these bearings should be worn out in only 2000 miles. The machine shop really d!ck up.
It seems all the reliefs on the side of the journals were cut, except for the number four journal. On one side it was only cut halfway around (on your left):
The main bearings look OK, probably because they don't have much load on them. But the journals are still rough.
The cylinders have some scores on them. They can be felt with your finger nail, but they don't seem too bad.
Another funky thing is the number one rod was installed backwards. The piston was right in the cylinder, but the rod was installed in the piston backwards. Notice the orientation of the lettering on the number one rod (left) compared to that of the number two rod (right). Luckily the rod cap wasn't on backwards:
The machine shop may not have offered to do anything before since there was nothing to be proven to them, but everything in this bottom end is on them and we have a record of their part in it. Now they may be a bit more cooperative.
float_6969 wrote:I think when you go in to talk to them you should just lay a big a** hand gun on the counter before you start talking to them. And then tell them how much you miss being a professional arsonist.
I'm really liking this idea right now. Kyle, we may need your help...
Also, my stepdad thought there was an excessive amount of side play for the rods on the journals, or at least on one of them. He said he's put some loose motors together before, but that was really a lot of play. I'll ask him about how much play he thinks there was (he didn't measure it). Any comments?
