Not yet. Where is it located?s13sr20chris wrote:hmmmm, did you try whacking the headlamp timer unit?
Could I get a better descrition of the box? Color maybe? Thanks.s13sr20chris wrote:by the drivers feet. its a small box. im not sure if its behind the knee bolster or behind the kick panel.
The switch was used but it was from my parts car and the lights did work properly on that car. Since I have the parts car, I don't mind swappibg parts back and forth to see what the problem is.NISTECH wrote:Where did this replacement head light switch come from? New or used? The box is either white or green. The fact the lights do jump up when 2 other options are used leads me to the switch as it did Chris. I will breeze through the diag and see if I can give your a better guess to hang a part [since it is your money] but it would be more cost effective for you if you tested some circuits to determine what exactly is failing in the system. Not slammin you here just trying to save you some green back.
Ok, found it and swapped them out. But it didn't work...NISTECH wrote:The difference in operation between the 3 modes of opening is the time control unit recieves a signal on terminal 3 when turning the headlights from parking lights to headloghts[the point at which the motors are suppose to operate to up] In the other 2 choices it does not send a signal to that terminal. BUT that circuit also uses its own fuse. so you need to look at the fuse too. Note though that fuse supposedly also powers your marker and tail lights. Still check to make sure the 3rd fuse up on the right side of your fuse box in the drivers kick panel has power on both sides when the switch is turned on. It is a 15 amp fuse. If it does go to the time control unit and do the same test on terminal #3 with the switch turned to the on position. The timer is located in the drivers kick panel, and its black not the colors I mentioned before. When you pull the kick panel trim off you will see 2 controllers one white and one black. the one further in is black, that is the unit your after.
