Headlights + Elec Fan = Horrible Idle
Katapl
Car: 91' R32 Sedan
The battery was fully charged on the test. The problem has been progressively getting worse. It's hardly able to sustain idle with just an electric fan on, and nothing else now. Like I said, when an accessory was on, it didn't just drop. It dropped more, and more, and more and so on. This friend of ours knows plenty more than I do, and he's certain it's the alternator. I'm going to have it rebuild for more amps while it's out. Then I know I'll never have any issues like this again. The car has been running specifically off the battery, apparently.
float_6969
Keep us updated and let us know how much the rebuild was and how the car runs now.
Katapl
Car: 91' R32 Sedan
float_6969 wrote:Keep us updated and let us know how much the rebuild was and how the car runs now.
I will update the thread when I have it rebuilt and back onto the car. I will not be able to take it in until at least Tuesday or Wednesday, though.
Katapl
Car: 91' R32 Sedan
Dropped the alternator off earlier today. The guy told me it would be about $100 to rebuild, and I should have it back about Friday. He also said that being an 80 amp, it outta actually put out more like 100 when it's rebuilt to like-new.
I'll let you guys know how it goes when I get it back and bolted on.
maik21
Car: 90 Nissan 240SX Coupe 5.0
i will wait for results !!!
Katapl
Car: 91' R32 Sedan
The alternator now puts out 13.89 with EVERYTHING on, but the idle still isn't fixed. It idles horribly with everything on... still. I unplugged the AAC plug on the side of the intake, and it basically ran worse, so I couldn't say it was that. It idles down to 500 with everything off when I unplug the AAC plug.
Could the timing possibly be off a little? Though, I'd doubt it since it drives great and has full power, besides idling.
p.s. the rebuild cost was $105 for a full on complete rebuild.
Modified by Katapl at 10:56 PM 4/18/2008
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
if you are getting a code for your CAS........ dont you think you should probably check it?
Katapl
Car: 91' R32 Sedan
I didn't get a code for the CAS. I only got a knock sensor code last I checked. I'm just wondering if perhaps the timing is off a little, but even that shouldn't effect the engine ONLY when I draw more and more power.
DALAZ_68
Car: 90' 240sx CA18det
then maybe take the advise of the other guy and get new mounts...
or silicone fill ur old ones...bam solid mounts
ca18detgabby
03 Infiniti G35
Katapl wrote:I didn't get a code for the CAS. I only got a knock sensor code last I checked. I'm just wondering if perhaps the timing is off a little, but even that shouldn't effect the engine ONLY when I draw more and more power.
sorry my bad mis-read
woudl consider checking out the knock sensor and timing.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
And you can never have enough ground wires. Its kind of ridiculous what a difference it can make.
maik21
power wires need to be equal to ground wires... i mean gauge... current in its equal to current out. so wires need to be equal...
for the op... try to change your mounts, if there arent expensive, u will not lose anything...
r34 gtr
Why not more ground wires than power wires? Ive got a whole bunch of massive ground straps and it made the difference between running and not running one a few occasions.
maik21
current travel from +point in your battery and goes to the electrical system then return to -point on your battery. some times u dont use ground wire for your accesories because u use chassis as a ground point, but anyways... chassis needs a ground wire to battery.
maybe u dont understand but wires needs to be equal with the correct gauge. i dont teach you anything, but i study this stuffs for a while. if it works for you great, but u can save some money if u do it right.
Katapl
Car: 91' R32 Sedan
I'll try adding a thick ground about the same gauge as the battery cable for another engine ground. There's already a good ground on the battery, and it goes to the spare tire slot thing section in the trunk (being where the battery is).
While I was at work, my father adjusted the idle a little bit by hand, and the car held idle with everything on. I may just up the idle a small bit if I can't figure anything else out.
Thank you all for the help so far.
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
did you use 0 ga power wire and ground ? thats what i used on my kinetic battery relocation.
Katapl
Car: 91' R32 Sedan
splintercell wrote:did you use 0 ga power wire and ground ? thats what i used on my kinetic battery relocation.
I used what came with my summit kit. It was the same gauge as the positive cable.
float_6969
Set the idle and timing via the process laid out in the FSM.
Katapl
Car: 91' R32 Sedan
Is it highly necessary to install a fuseblock up front when you do a battery relocation? Here's what my power supply setup looks like in my engine bay.
<Warning> BIG PICTURE.
http://img149.imageshack.us/im...7.jpg
splintercell
heres my setup
SARD battery boxKINETIC AUDIO deep cycle battery0 ga power and 0 ga ground 1.5 ft grounded to spare tire bolt downmobile spec distribution block w 250amp wafer fuse.
biosehnsucht
Katapl wrote:Is it highly necessary to install a fuseblock up front when you do a battery relocation? Here's what my power supply setup looks like in my engine bay.
How is that positive cable attatched from the battery cable to the alt/etc wires? Can't see past the tape... that could be a problem area too if its a poor connection, electrically speaking.
Katapl
Car: 91' R32 Sedan
The battery cable, alt wire, accessory stuff and my fan are pretty much stuck together with a bolt and screw holding them all together.
I tried screwing with the timing today, and I fully advanced the timing and it ran almost perfect. I'm scared to leave it like that. I'd hate to shell-out an engine with so much advance
I'm just gonna have to put a light on it. With advanced timing (according to CAS) it started acting a bit weird, so I turned it back, and now it ran as good as it did yesterday with advanced timing.
Modified by Katapl at 12:19 PM 4/22/2008
Katapl
Car: 91' R32 Sedan
Timing is at 15 degrees.
Katapl
Car: 91' R32 Sedan
Okay, and here is what we have for a power supply setup in the engine bay...
http://img152.imageshack.us/im...6.jpg
The cable from the left is the battery in the trunk, the connector above that runs right into the harness, and the connector below the battery runs into the fuse block (which you can see) harness. The fan is the black wire with the yellow protector above that.
You can see there's really no fuse block at all there. They're just all connected together with a bolt and nut.
Could that be the problem?
biosehnsucht
maybe your CAS has skipped or the timing belt is off?
could also be too much fueling, I remember when I was having all kinds of trouble I could crank the CAS all the way and it would idle smoother... but didn't trust running that way. I eventuall set it correctly to 15 BTDC. CA's don't generally like advancement..
Katapl
Car: 91' R32 Sedan
It's been set back to 15 degrees earlier today. I also added a ground strap from the engine to the frame. Nothing has changed.
biosehnsucht
Well, you might try a 'proper' connection between the battery and the alt/accessories, just to rule out a bad connection there. I'm not sure what the relative conduction of different bolts would be to a 'proper' purpose-made piece of equipment.
Other than that, if it's struggling at idle, and the alt is strong, perhaps its a fuel/spark issue. Check the plugs, and test the coilpacks and igniter. Possibly try disconnecting a coilpack at a time to see if it affects idle at all. Are you running stock injectors / CA MAF / ECU ? Is the O2 hooked up ? Is the O2 new or relatively new, or is it the one that came with the motor?
I'm kinda grasping at straws but I know my car struggled at idle when it was running overly rich, but seemed to run fine under load.
Katapl
Car: 91' R32 Sedan
All that stuff is stock, and the o2 is hooked up. It looks relatively new. I think the car could possibly be running rich, though.
It's not simply struggling at idle... it's struggling when I draw too much power. I.E. headlights + brake lights + heater + fan, etc
ca18detgabby
03 Infiniti G35
not as bad as you discribe but I had a little issue like this and when I went to the cheapo copper plugs and it ran amazing
splintercell
i still think you should yank that power wire and ground and replace with 0 ga power and no more than 1.5ft of 0ga ground off battery. most of those relocation kits are 4ga sometimes 2. ive installed at least 5 battery relocates and never had any issues.
