The engine is grounded from the intake to the chassis and from the exhaust side head to the chassis (which I added tonight per suggestion).float_6969 wrote:Is the engine grounded to the chassis? There should be a large ground cable that runs from the intake manifold to under the battery tray.
so when the motor is under a load, it doesn't idle up like it should? What happens when you turn the wheel with the motor running?
Well, every accessory does this. It's not just a few. Opening a door so the auto seatbelt moves... small rpm drop. Turning on headlights... huge rpm drop. It just depends how much power each accessory uses.Bwana wrote:I would also consider the possibility that one or more of the accessories mentioned is pulling an inordinate amount of amperage...
No, that's the cold start gizmo. It has a wax thing that closes up as it heats up from the power running through the heating thing in it.Katapl wrote:
I suppose the idle control valve could have died. That's the piece that's in the very front on the manifold, right? It has a hose in, plug connector, and hose out, right? The connection and plug from the harness of that valve were severely corroded. I did my best to clean them up, and I think I did okay. When I tried running it without plugging that in, it ran worse that ever and idled up to 4k on just start. I immediately plugged it back in. Could it really have possibly died?
Is your sensor hooked-up correctly or even at all? I called it charging issues because not only the battery benefits from a properly functioning charging. And as stated from others, if your original idle is (let's say 800rpm) with accesories off, by the time you turn on those accessories, your rpms will drop because of the load.Katapl wrote:I pulled the codes, and I initially missed the first set that were shown. It had shown 2 or 3 different codes. I'm pretty certain one was 21, and that's ignition signal. When I tried again, all I got was 34, and that's detonation sensor.
Any ideas off this?
Well, like I had mentioned... it's all hooked up except the part I circled below.boost_boy wrote:Is your sensor hooked-up correctly or even at all? I called it charging issues because not only the battery benefits from a properly functioning charging. And as stated from others, if your original idle is (let's say 800rpm) with accesories off, by the time you turn on those accessories, your rpms will drop because of the load.
Dee
That piece is unhooked and showing two prongs for a connector.
in 1996, my father had a nissan luccino with 2.0 sr20de... and it has a similar problem u have. the code in ecu was knock sensor and it shows because engine mounts were damaged.... so he replace them and problem was solved.Katapl wrote:By the way, this problem is progressively becoming worse. Now it seems if I'm just sitting in the car with the fan on, it drops if it sits for longer than 5'ish seconds.
The only ECU code I got was knock sensor.
im not lying.. the mechanic told to my father , car need new mounts because knock sensor was shown in the ecu code error. so they put new mounts on it and problem was solved... i dont try to say u need to put new mounts.. its only a 1 more way to solve ur problem.Katapl wrote:Was it a similar idle issue? It just doesn't seem right that the idle would drop because of an engine mounts. Though, yes, the engine mounts are kinda tore-up on this thing.
If it was simply a mount, I'd order a good set of NISMO ones have this thing done.
oks.... if its ur alternator... with all accesories off and engine on, u will see a 14+ v in the battery. if ur voltaje is 13.5 or 13.8, u will need to charge first ur battery and then check again voltaje... if battery is fully charged and voltaje its 13-13.8 then u have a bad adjusted belt . u will need to torque it again.Katapl wrote:Okay, someone reputable just put a multimeter to the alternator, and it tested bad. Apparently, the voltage kept dropping and dropping while accessories were on. I don't know how these other places tested it, but it's definitely not putting out enough to keep everything up.
It could be a bad regulator. That would explain why sometimes it runs good, and sometimes it runs poor.
