^^^ Completely disregard that post ^^^ I did the test wrong
I mistakenly was measuring the horn relay terminals, the picture made me think I was checking the 1st and 3rd socket on the bottom row.
So heres all the tests I just did though. Getting good use of this multimeter lol
I do infact have voltage at pin 1/3/6 on both relays
I also checked resistance between pin 1 and 2 on both relays and both measured 70.5ohm, All 4 headlight fuses in the fuse box by the battery had voltage.
Heres a kicker problem though, you said
Chuck Tribolet wrote:
Now plug in the relays, and turn on the lights. You should have battery voltage on pins 5 and 7. If you do, go on to checking the combination switch in the next paragraph. If you don't, check pin 2. If it has battery voltage, you have a problem with the headlamp battery saver control unit (this is unlikely because the same pin on the battery saver controls both side relays).
But both pin #2 female sockets did infact have 12V with the car and lights off...
You can see what pin in probing in the pins when I got 12V at both #2's. Im going by the little diagram numbers ontop of the relays, hope thats right
And also, you said to then check for voltage at 5/7 but how do you do that after connecting the relay, were do you probe?
Only my passenger headlight HIGHBEAM comes on when I turn the highbeams on, the dash indicator does work though, which you mentioned saying meant the steering column switch was good.
Whats all that mean? That I have a problem with the headlamp battery saver control unit ?
