CanuckQx4 wrote:So I took ridiculous good care triple checking the pin numbers on the bottom of the relay.
The relay closest to the front of the car, for the passenger side light appears to be good, all 5 pins have 12V (except pin2 like you said)
But on the relay closer to the firewall, for the drivers side light, was not as lucky. I noticed pin 3 had significantly lower voltage than the others that were showing 12V, it only had 10.9volts. (Pin 1 & 6 had 12v.) And pin 5 & 7 had no voltage (was some small MV number)
The highbeam indicator did not function in either push or pull configuration, but I believe I already tested that the switch itself is good earlier on.
Hey guys, after reading the posts again, I keep coming back to this statement that the voltage on pin 3 is low.
This voltage is coming directly from the #60 (15 amp) fuse. It should definitely be +12V.
Pin 3 is also hardwired (somewhere) to pin 1. Both should have the same voltage.
FYI, pin 1 voltage provides power to the relay solenoid, and pin 3 voltage goes through the contacts and on to the lamps (when the relay clicks on).
Just to be sure, check voltages again on 1 and 3 with the relay removed. There should still be a good strong 12 volts there.
Keep us posted. (Chuck, hope you don't mind if I try to help as well. I enjoy this kind of troubleshooting).
Thx.
