stillen is already doing a 2.5 headers read the rest of the thread so if sfr wants 2 do the 3.5 let em do it.. anyway.. someone be a guinea pig for SFR!!!Stumpjumper wrote:SFR needs to do one for the 2.5
Never said they shouldn't, I'd just like to have optionsMr_Coupe wrote:very true however i think the 3.5 should also get them id rather have both the 3.5 and 2.5 to have them rather than just the 2.5.. i doubt the 2.5ers are th only ones that want increased HP
ahhh it makes me so madddStumpjumper wrote:We're getting lots of posts of "This part is in the works" and then no updates.
Well, I remember spockrock saying that some company has a y-pipe in the works. However, I do not remember him ever saying which company. It seems like a good mod that should be pretty cheap, the only issue is emissions.EzeebMOS3 wrote:I know stillen come on!!!!!! Atleast get a Y-pipe out soon! It takes no time at all to make
Well the MAF sensor is located on the intake before the air even reaches the engine. So exhaust and headers wont really have any effect on your A/F ratio it just helps it "exhale" easier... Even if it did tho the ECU will compensate and still use the right amount of fuel so you dont run too rich or too lean. Thats the whole point of havin it there.Flypinoy457 wrote:Besides the headers, anyone have any insight on a possible fuel management system for our car, something like a simple piggy back like a Apex'i SAFC. Having a header and exhaust will do a number on our A/F ratio, most likely run rich since the stock MAF will just try to dump as much fuel as it can to compensate for the more air flow.
well before i get madd at stillen, it hasnt been 60 days yet.kyle@stillen wrote:We are almost finished with our headers for the 2.5...These are coming along very well and should be available within the next 60 days. The initial design and testing will be finished in the next week or so.
They should only look for a check engine light and run it through the computer. If someone wants to really get specific with you, the primary cats should will still be on the car. They're the ones that do the all work and tell the computer whether or not you have a working cat on the car or not.EzeebMOS3 wrote:We'll you could just put the stock ypipe back on before you went to get your emmisions tested....that's what im planning on doing..... I'm just gonna cut out the third cat and have a pipe put in, however keep the cat and just clamp it back on before i need to go for the test (every two years i believe). Unless a ypipe mod comes out soon, than ill just bolt that on and do the same process.
AltiCoupeDriver wrote:This really isn't a mod friendly car is it. What do you guys say about a y-pipe or does it fall in the same dilemma?
