Density changes with temperature for a gas.charlieo wrote:
The speed of sound is temperature, not density dependent.
Speed of sound IS definitely dependent on the medium it is traveling through. The speed of sound under water is something like 4x faster than it is through air. Probably not due to density though, more like some other physical property (think about why sound deadening material, which is pretty heavy, deadens sound).
Regardless, the air temp at 100,000+ feet has got to be pretty damn cold.
I wouldn't really worry about him "burning up". He won't be going anywhere near fast enough, nor will he have the required mass to keep up that speed into a point of the atmosphere that is dense enough to generate that heat.
Planes travel at what, 550 mph? Only a hundred and change mph under what he will be traveling at, and their windows/wings ice up... at lower (denser) altitudes.
And I just wanted to say that the first guy that did it (Joe) way back in 1960 had way way way bigger balls than this guy does.
