Yeah, saw that on another forum a day or two ago. Definitely pretty intense.ScorchedNX2K wrote:http://www.popsci.com/technolo...-fall
What a man, what a man, what a mighty good man...
And I thought you were going to say posting on NICO would be bad a**.AZhitman wrote:If he was TRULY badass, he'd be tweeting on the way down, lol... What a killer ad for the iPhone / Blackberry / Droid THAT would be.
Wonder if you get better reception when you literally standing next to the satellite I dunno that he has to "work" to overcome it. Really nothing much he could do. I mean, they could throw rockets on him... but that kinda defeats the purpose.AZhitman wrote:Damn. This is awesome.
I'm no physics whiz, but it seems to me he's gonna have to work JUST to overcome drag and increase his terminal velocity.
The record-holder did 614 mph, he needs to exceed 768 mph.
But yeah. 30-40 seconds of subsonic speeds, then another 6+ minutes of free-fall? DAMN.
Red coupe wrote:I dunno that he has to "work" to overcome it.
He probably has to hit the most aerodynamic pose possible and hold it...
That's what I mean.... imagine holding your arm out a car window at 80 mph... Even in a [rigid] knife-edge position, it's still effort. He's gonna be experiencing 10x that speed (then again, thinner atmosphere and all)...Red coupe wrote:Holding himself ridged and as pointy as possible will likely get tiring,
Still, if he so much as gets a little "out of position", it's gonna be a hell of an effort to get back "in line"... Makes you wonder if there's the possibility of injury from a limb flailing about like a flag on an antenna, lol.
Regardless, I guess there's some benefit to all those slacker kids, sucking down Red Bull - We get to see cool s*** like this in the name of science!
768mph is the speed of sound at sea level, but as altitude increases (and air density decreases) the speed of sound drops. At 4200 feet (Salt Flats) it is in the 740mph region. At 30,000 feet it's only 648 mph. So 614 was probably damn close to breaking the sound barrier depending on the altitude it was reached at.AZhitman wrote:The record-holder did 614 mph, he needs to exceed 768 mph.
Red coupe wrote:You think the guy will get bored half way? It IS a 7 minute free fall... After like 4 you think you'd be all like "Yeah, I get it.. I'm falling..."
themadscientist wrote:Why would he go supersonic in a free fall. Terminal velocity for a falling object should be much less than that.
When your falling you reach terminal velocity because you are hitting so many particles of air, all of which have some mass. To get by you have to push the particles out of the way, which means they push back on you.Red coupe wrote:drag depends on the density of the fluid (air)
I still say it wont be anymore violent then any other freefall at terminal velocity.ScorchedNX2K wrote:In regards to the threat of him injuring himself from limbs flapping in the wind....I think the suit he is wearing has some kind of rigid frame built into it.
Don't really know much about atmosphere stuff... But it should be a steady change, so he wont "hit" anything, air will just get thicker and thicker and he will steadily slow down.ScorchedNX2K wrote:Yeah but he'll be hitting the denser atmosphere going extremely fast...
The speed of sound is temperature, not density dependent. Well, for a gas, anyway. When we look to calculate true airspeeds and then groundspeeds based on Mach, we look at the temperatures at altitudes.MinisterofDOOM wrote:
http://www.ucar.edu/learn/1_1_2_2t.htmthemadscientist wrote:Why would he go supersonic in a free fall. Terminal velocity for a falling object should be much less than that.
The "minimum" speed of sound in normal atmospheric ranges (not including the outer layers) is around 40-65,000 ft, it actually goes back up again slightly above that.charlieo wrote:
The speed of sound is temperature, not density dependent. Well, for a gas, anyway. When we look to calculate true airspeeds and then groundspeeds based on Mac, we look at the temperatures at altitudes.
danshaz82 wrote:isnt terminal velocity of an average human 120 mph? they did a test about it on mythbusters at one point
No, there is no one terminal velocity for a human. Terminal velocity is based on drag, drag is based on shape and density of fluid. Air gets less dense high up. He is going high enough that there is almost no air, so almost no drag.Red coupe wrote:
The faster you go, the faster you are trying to push them out of the way, the harder you are pushing on them and the harder they push back on you.
At some point, the force they push back on you with (your drag) is equal to your weight... This is terminal velocity.
If you picture a column of air that goes all the way to outer space, the density of the air at the bottom of that column comes from the fact that it has the weight of all the other air on top of it. As you move up in that column there is less weight compressing the air, so it spreads out more and gets thinner.
This is the whole reason he has to jump from so high.... Its not so he has enough time to reach the speed, sky divers easily hit terminal velocity at much lower altitudes...Notice they anticipate him reaching the speed of sound only 30 seconds into an almost 7 minute free fall. The height is so he can be falling through air that is thin enough to limit drag to the point where he can achieve the speeds he is aiming for.
