Hardbody Lift Kit
Nismo902
Car: 2008 Nissan Sentra 2.0s B16
2003 Nissan Sentra SER Spec V B15
1996 Nissan Hardbody EXT XE 4x4 D21
1977 Chevy Camaro Z28
1966 Chevy C10 Long Bed
hello I am new to the forum and I am looking at getting a lift for my 96 Nissan hardbody but I am not having any luck finding a kit, I found the rough country lift but seen some horrible reviews on it any recommendations?
centralcoaster33
Car: 1997 Nissan 240SX #5
Welcome to NICO Club!
I don't have a hardbody. Have you done searching for D21 lift? Are you considering a body lift kit as well or just suspension lift (you know I don't know this truck if there is no such thing, ha!). I did do a search and found a nice looking kit that costs more, called Calmini - Nissan Hardbody with a 3" lift. https://www.calmini.com/detail.php?b=1&m=4&t=1&p=588&n=
Try looking into our older threads for some information as well. Here's a couple I found, there are more...
hardbody-lift-kits-t214994.html
torsion-bar-lift-t454169.html
calmini-vs-trailmaster-lift-t477290.html
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Any IFS lift you do should be accompanied by a better steering solution, or you'll find yourself eating up steering parts at good rate.
Calmini also has steering kits to accompany their lifts. I'd consider this a must have if you plan to lift the truck.
the lift in the front is all in the torsion bars....the longer UCAs compensate for the lift and still enable you to get alignment into spec. The Nissan A arm lifts compromise down travel for more ride height, and up travel is increased. That means it really doesn't give you a lot for running bigger tires. Fender trimming is where you get that. 32" rubber on wheels with at least 4.5" backspacing is about what you can expect to be able to run. If combined with a body lift you can squeeze 33s under it.
