Calmini vs Trailmaster LIFT
JC87HB
Car: 1987 Nissan D21 HB
im currently looking at a V6 4x4 D21 with an auto transmission.. i was gonna choose one of these kits to put on it... Which kit would you guys recomend?? I really like the calmini kit but the trail master kit looks pretty sweet...
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You can get more lift from the trailmaster lift, but it does drop the torsion bars down low and leaves them exposed and unprotected from trail obstacles.
You can actually stack the lifts...run the TM lift with the Calmini A-arms for a total of 6+" of lift, but you' absolutely need a steering solution that's better than stock, because the stock stuff just isn't up to the task.
JC87HB
yah i figured.. but im really only interested in running a 31" tire at max.. i dont want anything rediculous.. cause it would be a DD...
seang
Car: Ford Fiesta ST
I used to have 31x10.5's and I could turn the wheel lock to lock and they would never rub on anthing, my truck is stock height 4x4. Even flexing it off-road, they never rubbed. I do, however, have American Racing wheels, and I'm not sure if they have a different offset than the stock steelies my truck came with.
JC87HB
well i have after market rims on my current nissan that i will be puttin on the 4x4... plus i just want the lift for more ground clearance and the more agressive stance! i appreciate your input seang!
