...and Bingo was his name-o!JC87HB wrote:so... reindexing... all that is, is just reseting the adjuster arms to a normal position but still obtaining lift via adjusting spline? and is taht all it does?
Thats what I meant by shims.JC87HB wrote:what about BJ spacers?
^^IDK about this little hypothosis of mine, I hope DR has some input on these.seang wrote:I wonder if you can shim the upper ball joints to compensate the angle, but this is all in my head. Also, cant the upper control arms be modified, (aka cut and welded with more steel to lengthen).
Thats what IDK, I wouldn't reccomend you snake oil...JC87HB wrote:they do make BJ spacers... and they are alot cheaper.... so.... would they compenstte for the angel though? hmmmm
