RobertsnewQ »
https://forums.nicoclub.com/robertsnewq-u29366.html
Fri Dec 09, 2005 8:01 am
The base (no knock) timing map is LESS aggressive than JWTs in a couple of spots (mainly 2000 RPM and 4000 RPM at high loads), because the JWT map causes knocking on 91 octane at certain RPM/load points. Knocking means it will switch to the low octane maps and then you don't have much benefit.
However, I have INCREASED timing in some areas (cruise, throttle tip-in, high RPM) at the same time. The peak HP should be more than JWT, but some low-RPM torque spots will be flatter. The off-idle performance "snappiness" is AWESOME compared to stock, and much better than the std. JWT tune.
If you live in a 92/93 octane state, I raise most of the high-load timing up one or two points from the 91 octane map. The knock map is the same for both, so if there is a problem it will just revert to that. The knock map is slightly more aggressive than stock, but a good 1-2 points retarded from the no-knock timing map.
You should see the advance curves on a JDM modified ECU I have (I think it's Impul). It is AGRESSIVE!!!. The stock JDM map is actually pretty good as a modified map for us - it's conservative for their gas but slightly aggressive for ours!
The stock USDM timing maps are the same (actually they get MORE aggressive in the midrange!) from 1991-1994. 1990 is a special case, the ECUs had more aggressive no-knock timing (by 1-2 points) but more conservative knock timing. The fuel maps change somewhat, probably for emissions or fuel economy reasons, although the USDM fuel maps are richer than the JDM maps - I think it's because we have cats that have to be fed some unburnt fuel to live for 100,000 miles.
As for engine longevity, there are two factors.- higher RPM limit. This will stress your engine more IF you bounce off the limiter all the time, but if you do it once in a while it probably won't matter too much. I can leave it stock if you want.- The catalytic converters. Since I leaned out the high RPM/high load areas of the fuel maps, the cats won't get as much cooling from unburnt fuel at WOT. If you are planning on driving around at WOT all the time, again, the cats will fail sooner than Nissan intended. How soon is hard to say - if you've got over 100k on your original cats you're on borrowed time anyway.
I can do a map-switching thing with two different programs but there are two caveats:
- It will cost you $40 more (because I have to buy a board, and that's what it costs me to buy one w/shipping)
- You can only switch maps while the engine is NOT running. If you do it while the engine is running, it will cause the ECU to reset, and could cause a lean spot. Don't do it.
