GROUP BUY: USB CONSULT!
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
No worries, it should work typo's and all :-)
Scott
tubesguy2
Okay, I'm missing something. In Wes's "Z profile" it says "no contact information"
Where can I find the email address? I'm in, if I can paypal today I will. TIA - Pat
tubesguy2
Never mind ... it's the other profile.
tubesguy2
Paid. Thanks guys, for putting this together. - Pat
Skibane
Car: 2000 Q45 AE 110K
Once again -
Jamie: Does your CONSULT interface require a different Data Link connector in order to be usable with the late-model Y33?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
tubesguy2 wrote:Paid. Thanks guys, for putting this together. - Pat
Got yours pat... 8 to go!
slipnfall
Car: '06 D40
Skibane wrote:Jamie: Does your CONSULT interface require a different Data Link connector in order to be usable with the late-model Y33?
Hi Skibane: unfortunately the second gen, Y33 uses the CONSULT-II protocol, which will not work with these boards. Sorry! I saw your original post and was actually looking for a schematic until I noted the year.
slipnfall
Car: '06 D40
pdqwrx wrote:In an earlier post you said that this cable is a read only device- Is that because of the cable or because the stock ecu is a read only device as well?
Well it is by default, a limitation of the coding on the stock ECU. The PLMS board is as Wes said, basically an EPROM emulator with a graphical interface and CONSULT functionality. If you can chose a COM port from the application, this board will work fine with that software(of course no map changes are possible).
qsiguy
Car: 1994 Infiniti Q45 Turbo
I want to get in on this but I won't have the funds for a couple weeks. Any chance I can reserve my unit somehow?
Very nice work Jamie! I contacted you a while ago about getting one of these but wasn't able to swing the money at that time and forgot about it. I don't want to miss out again.
On another note Jamie, do you make the PCB's yourself or do you have them made? Reason I'm asking is I have a few circuits I would like PCB's made for but don't have the time to make them myself, just too many projects on my table right now. I have software to design them but that takes time too. If you do these yourself and are interested let me know. Idealy I'd like to send you a diagram and have you lay it out on the PCB, drill, and etch them. You can e-mail me if you want to keep this separate.
Thanks.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Wes- just sent ya the cabbage.
Jaime- Of coincidence, i was looking at your stuff on ebay just the other day before Wes posted up this thread. Was on the fence, but now that i know i've got tech support from a NICO brotha it's even worth the extra $5.
for other folks interested, there's a group called BLAZT that also offers cables (don't look as clean IMO) but perhaps more importantly, they offer a software package including a datalogger (Brian) for $50.
slipnfall
Car: '06 D40
qsiguy: The basic CONSULT 'concept' circuit is that which is publically available. The design as a whole however is done by myself, including the addition of the USB bridge, 95% surface mount components, all the component tweaking (values), and some additional reliability. So is the PCB layout. The boards are manufactured at an off-site boarding house, and are about the best quality FR4 boards you can have made. The units are hand assembled and tested by myself on my own S13.
These PCBs have soldermask layers, which the cheaper units do not(this is the green that you see). This keeps corrosion from forming on traces and in the end, results in a longer lasting, more reliable device.
GQ Jay:Yes Blazt is a good source for the Nissan DataScan software and the DataLog *viewer*. I emphasize the viewer, because the logging is a function of the DataScan: you can still view the log files with Excel, but it's a PITA. The optional viewer piece of software just makes this much easier.
Of course DataScan and LogViewer are completely compatable with these cables, and I highly endorse DataScan.
kev1n
two questions
1. would this work on an F50 Q ?2. Can it do any modifications to the such as re-register tire pressure sensors ? adjust timing ? etc ?
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Hey now!!!!!!!!!!!!!! I am a little slow(but thats ok cause my car and my woman is fast) that being said, i am at the last of my last compound of rubber on my pirellis and it is alot of fun. (a little aside, must still be drunk from last nights JD infusion).BTY Did i say $ sent. thanks Jamie and Wes.Will this read secondary TPS ?Wheel Sensors ?Paramaters have to be changed mechanically ? ie timing but u can watch it realtime on laptop.Gonna dig up an old small as possible laptop to install in car.NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks for the heads up Jay and Jamie.
slipnfall
Car: '06 D40
kev1n wrote:1. would this work on an F50 Q ? 2. Can it do any modifications to the such as re-register tire pressure sensors ? adjust timing ? etc ?
Kevin: sorry, but these boards are for early-mid 90's Nissans and Infiniti's only.
There is a timing adjust function which relinquishes all control of timing and locks the IAC valve to allow mechanical adjustment.
elwesso
2007 BMW M Coupe
I got payment from:
GQ JayPopPopmaxnix
5 more left!
ponzy
Car: infiniti q45
elwesso wrote:I got payment from:
GQ JayPopPopmaxnix
5 more left!
just logged in ........ paypal is ready, what 's the paypal account?
ponzy
Car: infiniti q45
payment sent to [email protected] <[email protected]>
where can i get those software compatible with the usb-consult?..pls email me ponzyq45 at yahoo dot com
..............i hope i'll be able to fix my q tom......otherwise i'll send it to a shop monday
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Heads up Ponzy, You can do it!
elwesso
2007 BMW M Coupe
ponzy wrote:payment sent to [email protected] <[email protected]>
got it!
slipnfall
Car: '06 D40
Here's a thread with some links to various CONSULT software programs.
zerothread?id=198192
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Thanks. Datascan looks like a winner, but is another one required for diagnostics?
slipnfall
Car: '06 D40
No, DataScan does it all: there is a seperate program to aid in viewing the datalogging, but it is not neccessary.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
What is the extra program? Guess I need to go back and study the offerings again. I thouight datasccan was the acquisition and dispaly program, hence my question about diagnosis.
slipnfall
Car: '06 D40
Sorry if I confused you. Here's the deal: DataScan does everything from display the data(on-screen gauges) for timing, temperature, RPM, etc, allows you to turn off cylinders, temporarily adjust things such as timing, AAC valve, etc. It also allows you to record all of this information to a file, aka datalogging.
Now, you can open up that record file in Excel, and see rows/colums of information. If you want to be able to view that information in nice charts and graphs, the *other* LogViewer program just makes this easier. You can still do it in excel, it just take a little time.
Hope that helps!Jamie
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
OK, I got you. DataScan + LogViewer
I guess I could rely on pivot tables.
So, if my Q runs fine and I've gotten by these four years without ever needing a CONSULT, then do I need one of these?
slipnfall
Car: '06 D40
Yes.
ponzy
Car: infiniti q45
where can i get a free nissan DATA SCAN? jamie i checked the link but the link on data scan is: "Internet Explorer cannot display the webpage"
how much is to purchase a software for your usb-consult? i am not an engineer but basically all i need is a basic diagnostics and how to reset that i guess and prolly fix some issues?
will it read all/most of the codes from the original consult form misfires to sensor failings right? if these usb-consult will know what's the exact problem on the car, i would say this is a must-have for G50 owners.
thanks for your geniuses..........
slipnfall
Car: '06 D40
ponzy: DataScan is not free, but there are plenty of other free programs out there. Check the link I posted above.
If you would like to purchase DataScan 1.5, it is around $20-25USD if I recall correctly. It also is in the link above.
Yes you can pull the diagnostic trouble codes stored in the ECM.
