Agree! Forget any electrical upgrades unless it is to increase capacity for audio. and if one should go with HFCs make sure they are high quality ones.Poyzinous wrote:stillen intake and exhaust maybe?
(EDIT: THESE COMMENTS ARE INTENDED FOR THE OP)I'm looking at adding a grounding kit. Please SEARCH the site!!pfarmer wrote:
Perry
The only thing a grounding kit can do is fix a broken ground. So the fix for a problem is to fix the problem in the correct way.SVTCOBRA wrote:(EDIT: THESE COMMENTS ARE INTENDED FOR THE OP)I'm looking at adding a grounding kit. Please SEARCH the site!!
I'm REALLY surprised that more members that HAVE installed these kits (especially Nate's) have not chimed in.
Modified by SVTCOBRA at 8:41 PM 8/19/2009
I would disregard any recommendations that can not be substantiated by verifiiable gains, especially when one of those recommendations comes with a statement about out performing modifications such as intakes and exhaust systems.Sentientbydesign wrote:Pfarmer doesn't like grounding kits and doesn't believe they do anything. If you're at all interested, go read the HUNDREDS of other posts on NICO and elsewhere that disagree with his opinion.
Then again, he has one of the worst track records with a G as well. Even if I had nothing to gain, I'd STILL disregard Perry's opinion of mods. Too much criticism, not much appreciation for them unless there is scientifically verifiable gains and even those are met with severe restrictions.
Yep, some are just tradeoffs for your wallet, some have more disadvantages versus gains, some don't give gains in the areas one really would like to have gains, and some in fact can be scientifically proven to give increased performance where the purchaser expects them. A performance modification should be able to be scientifically verified as such. An appearance modification needs none of this. Like modifications for sound they just have to make the user feel better.Sentientbydesign wrote:Just about all of the mods have trade-offs. You just got to let us know what you're aiming for (some, like 4drmadness) just want EVERY mod available
thats what it is...Sentientbydesign wrote:
The fact of the matter is, that you LIKE to poke holes in performance mods...because you can(?) or you think your background qualifies you to(?).
In the case of bang for the buck, if a 100 dollar ( at the consumer end) part would produce more horsepower then it may well be accepted, especially for a required part in the first place as it will sell more cars. Exhaust systems, things that change or increase sound levels may in fact produce more power, sometimes not in desired areas however. This is why I mentioned normal street use. If you dyno many intakes and exhaust systems you may well see a decrease performance in the rpm and load ranges where most drivers use their cars. This may or may not matter to the ones installing such systems since they will not necessarily be operating in these areas, but most of us actually spend most of our time driving outside of the area of benefits that many of these add ons provide. Most are probably installed for sound changes, not performance.joe603 wrote:Yes, our car was engineered by highly paid engineers...but you forgot to mention how many of there designs are "shot down" due to the expense. Infiniti/Nissan is in business to sell cars...as many as possible. I firmly believe that these aftermarket parts make up that gap created by the bean-counters.
Aftermarket parts also do not have to pass the "quiet" inspector. There are many people who buy cars and expect to not hear the engine. This is especially true with luxury marks. So the design engineers make the cars as quiet as possible (intake/exhaust). Aftermarket parts allow an owner to replace components that make the car louder. This will usually increase HP as you get rid of restrictive air paths to increase engine efficiency.
Now, the grounding mod...does the OEM system work acceptable, yes. Is there room for improvement, yes. To many people have purchased these kits without there being any results. I think it improves the sensitivity of the AUTO trans on the electronic side. Maybe it decreases the electrical resistance which increases the circuit tolerance or feedback providing more constant shift points.
The only real areas I have seen stacked grounds on these cars is where two conductors were placed in a stack, most grounding kits have more than this. On some 'G's you will see two conductors taken to ground on the front of the engine. Not a real good practice but as long as the bolt is essentially zero resistance then the bottom conductor which is grounded to the block and the top which is grounded to the bolt head then they should be essentially at the same potential. When a grounding kit has more then two you have the resistance of the ring connectors added into the stack along with the bolt which may or may not have been taken into consideration in regards to its resistance and ability to maintain it. Any aging of the rings now affect the entire stack with a greater resistance in the core. Some grounding kits avoid this, some with grounding blocks with no ring connectors, others with ring grounding blocks.Sentientbydesign wrote:Those highly paid engineers have utilized stacked grounds on the newer Altima, the FX35/45, the Honda S2000, one of the smaller Audi's (Can't remember the model), the Toyota Prius (if memory serves me).
I've seen what breather mods and a tune are capable of on our cars 250 ft lbs of MEAN (Average for all others reading) TQ and peak HP in the 290 range.
Another fact is that those highly paid engineers must have made some mistakes with your model as you are CONSTANTLY criticizing your G as being the most unreliable vehicle you've owned to date.
Please place both feet squarely on one side of the line.
Perry IF your car has 1-2 ohms of resistance in a wiring circuit, you have a problem. Now this is just ohming out the wiring. Not the componet on that circuit. That can had Mega Ohms of resistance. At max you should only have .5 ohms.pfarmer wrote:I challenge those with grounding kits to disconnect and measure for a missing ground. Most areas in an Infiniti are within 1-2 ohms front to back of the entire car. This is less of a deviation than the conductors in many grounding kits. Most grounding kits don't pay attention to equal conductor lengths to avoid circular currents.
Cheaper designs often win, evident by the early Mustangs versus the original design of the Mustang which killed it after it was demoed.kmckis1029 wrote:
thats what it is...
here is some insight from my background (degree in computer engineering, practicing electronics engineer)... one of the things i dont like about engineering is how much power the accountant has over design. In most cases, except when it comes saftey, the cheaper design wins and thats what is built. Then to take it futher the accountants dont want the product to last forever, so the product is designed to, in most cases, gracefully degrade so that you have to buy another.
But thankfully for cars and alot of other products this accountant vs engineer battle creates the aftermarket. Now you get aftermarket parts from companies that specialize in a certian type of part. Which in most cases would produce a better part than a car company that has to worry about cost of the total car vs just the cost of one single part.
In the case of grounding wires for the G35... in my personal and educated opinion they improve the g35... and its most noticable in the auto transmission shifting response, the response/exit time of the VDC, accelerator response, and of course a louder radio. i already had this argument with perry... not going there again...
oh and here is another example of engineer vs accountant... why does the 350z have a struct tower brace and the g35 doesnt? yes the FM platform is very stiff by it self... yes the 350z is a slightly different market... but if an engineer had his/her way the g35 would of had a struct tower brace at a minimum, if not other bracing... i mean the car cost more than a 350z already...
Mine measured zero, but this is a measurement that others have done which is based from the negative lead of the battery to any point on the car which relies on a ground. This appears to be common on various other car manufacturers as well as acceptable values.awdjdmtalon wrote:
I have had hundred of hours of dealer training, and in every class I attend, there is always atleast 2 hours of wiring circuit training. So I am speaking from experiance and training. I am not one to pull number out of the air. I want to be as factual as I can.
How about an issue with someone buying yours and ended up with this problem which appears to be improper stacked ground and or circular current related:Sentientbydesign wrote:So Perry, if you and your OPINION need verifiable evidence, please go find it on your own.
A PERFECT example of proof that these grounding kits work is anecdotal comparison. I've read numerous accounts of people who purchased Stillen Grounding kits for their Gs and noticed NO differences in the way the vehicle performed.
All but 2 of my customers have noticed improved performance. Coincidence? Not likely.
I've seen up to 4 stacked grounds on Nissan/Infiniti and more than that on the Honda S2000. Your examples are full of holes and 1-2 ohms did sound like a huge resistance, but I'm glad that Jerry was able to verify that from a technician's standpoint.
The numerous issues you have with your G make me curious if there is something that YOU are doing to cause the faults.
Oh you mean the problem two weeks before the post about fixing the car start issue by moving the grounding kit. Also he wasn't alone in moving the suggested location of the grounding kit and said they saw differences.Sentientbydesign wrote:Perry,
ENOUGH WITH REFERENCING VIVEK'S CAR. You have NO idea what he's done to that poor little sedan. The eventual fix to his problem was not moving the grounding kit. The fix was to replace his throttle body which is a common "dead item" on Gs.
Please don't come in here with your years of experience and claim to understand something that you don't. So far I just see lot of members dreading entering a thread because your name is the last post.
Oh and one more thing, Vivek drives that car like he's trying to run away from his shadow. There are numerous factors which effect the performance and faults of our vehicles. You can sit on your high horse and point fingers all day, but the fact of the matter is that the cars drive better. Even the 07/08s have been happy.
Remember to remove the grounding kit first or you will just measure parallel resistance.awdjdmtalon wrote:Ok here is what I am going to do for everyone today at lunch. I am going to measure the resistance from my Neg post to a few of the grounds from Nates kit. And to the Factory grounds. And I will post back w/ my findings.
And knowing that I am a ASE and VW Master Tech w/ 7 yrs experiance in the auto industry and 10 yrs in the aviation manitence industry, you know it will be done properly.
Are the factory grounds in place and not compromised?tollboothwilley wrote:Grounding wires do not improve the Newer 5AT or 7AT (2007+) like they do for the 2003-2006 transmission. That being said, the Grounding Kit on my car was one of the best upgrades I made for the driveability of my car.
Perry, you are more than welcome to come drive my car with and without the grounding wires so you can feel the difference it makes.
More resistance with something shorted? Actually yes as a parallel resistance. The rest is valid as far as causes including what occurs with stacked grounds.awdjdmtalon wrote:Ok here you go. I used a Fluke MD73AS3. This is a $200+ meter. The resitance in my test leads was .1 OHM. To simplify this all measurements I post are in ohms.
Back to the 1-2 ohms from front to back of the car. That is TOO MUCH. As I stated earlier. .5 should be the MAX you should have. More then that and you have something shorted, or corrosion in the wiring causing high resistance.
Rant over.
Modified by awdjdmtalon at 10:35 AM 8/21/2009
No where close. Note the stock readings are well within acceptable limits.Tampa G35 Sedan 6MT wrote:
This is getting fun...
Perry... I think they got you out numbered brother
LOL
No need to remove the ground kit. It only uses 2 factory ground points, as I indicated by the (F) next to the measurments. And when I measured those ground points, I measured on the factory wire ring and then on the SBD kit wire ring.pfarmer wrote:
Perry
