awdjdmtalon wrote:
I'm sorry not debate. I like a good debate that people can back up w/ first hand experience/knowledge, or proven facts.
Modified by awdjdmtalon at 10:41 AM 8/26/2009
You simply made my point that there has not been any presentation made in regarding to grounding kits installed with intact factory grounds providing any benefits. No 'proven facts' to support this statement:
‘I hate to advertise, but you can always look at the link in my signature and check out a grounding kit. It's cheaper than an intake and gives more noticeable change.’
If is also a proven fact that this is not so:
Go back to where I talked about, " You can take a single strand out of either ground wire you want an measure its resistance and get .1 ohms. But that single strand of wire CAN NOT carry the current or load that the entire bundle of wires can carry. "
While the statement about current is true, the resistance in stranded wire changes with the number of same size conductors it contains:
With standed wire using the same size individual strand conductor (#30) the resistance per thousand feet for some common sizes are:
16 gauge (26 conductors) - 4.03 ohms18 gauge (16 conductors) - 6.54 ohms20 gauge (10 conductors) - 10.47 ohms22 gauge (7 conductors) - 14.95 ohms
30 gauge (1 conductor) - 104.68 ohms
This comes into first hand experience and the knowledge of the difference between solid and stranded wire, which changes once more if claims are made about high speed signal enhancements. For example the use of single conductor versus multiconductor including essentially 'welding cable' has some real significance when it comes to signals.
We do have this statement:
'The grounding system can def. be upgraded in the 2003-2006 models'
The only arguement here is that it more or less pertains to all cars. Higher grade conductors, connectors not prone to future failures, etc. can always be found. When retrofitting this is certainly a good path to follow. Connection points should be properly engineered based on the knowledge of the system.
Then we have this statement once again when it comes to unverified claims:
'Makes a difference on more than just the 03-06. The 07 coupe is the same platform as the 03-06 and there are plenty of 07/08 G35 sedans that can benefit as well.'
Regardless of what the 07 coupe is based on the 07, 08, and I believe the 09 are all very similar in design in regards to charging circuits.
There are no verified benefits presented for a grounding kit on any of these models, however there certainly can be an issue of installing one as presented on the newer sedans due to the nature of the charging circuit. This is public information that shows that the same grounding kit has not been engineered for any of the sedans from 07 and up even if it had in fact been engineered for earlier models. The lack of knowledge indicates that the benefit claims can not be accessed. So toss any possible issues with circular currents or any possible benefits in regards to signal enhancements away and you still have an issue with bypassing part of the installed charging circuit on these vehicles.
To his credit Sentientbydesign has at least asked the question:
'Perry,Mind telling me where in the ESM you found this sensor? I'd like to take a look. Kind of odd that they placed it on the negative side and not integrated it into the fuse container on the positive side.'
Without calling him any names in regard to him selling a kit for use on these vehicles without knowing about this issue I gave him a reply based on my knowledge of a possible issue in this regard:
'The description is on page 8 of the FSM of the 2007 charging circuit.'
Have a nice day.
Perry
Perry
