Alright... so, step by step:
Lift the car... you don't have to, if you're small, but I'm 6'3... and I like space... anyways, after that, get under and start looking around. Near the cat, there was this brace to make sure the exhaust doesn't bounce around too bad.brace
axle flange
old exhaust muffler... see the mouting points? Check the one furthest from the tip, note that it curves, then compare to the one later on the new muffler...
Here is the cat flange, bolts up great, but check out that hanger... I don't have a hanger there... nothing to hang it on... oh well, I could impail squirrels (cept we put the stock exhaust back on)...
Brian ALWAYS puts something in backwards...
This is the rear most hanger on the driver's side... as you can see, it doesn't reach...
Here's a really awful shot of the hanger that did work, it was on the other (passenger) side of the muffler at the rear most mounting point... it did not fit well (did not stick all the way through the hole in the rubber), however, we barely got it on... it could easily have slipped had we driven the car...
This hanger... well... it's pointed the wrong way (note it's not bent toward the front like the stock exhaust hanger was) AND it's WAY too short... the exhaust did get over the axle just fine... not as high over as stock, but it did make it over and had all the hangers fit, I think it would have been fine (it's sitting real low cause the hangers weren't fitting)...
So... it doesn't fit. We started the car to see what it sounded like. It sounded pretty nice, very mellow, no fart at all, though we only revved to the low 2000s. The tip is larger than I expected too, as noted... it is the size of the Spec V exhaust tip... then, Mike found this picture of a Spec V hanger...
Yep, that's just where the resonator would be on a Spec V... in other words, the fabricator (which is not Greg himself, for everyone's reference) somehow got the impression that:
A. I have an SE-R Spec VorB. The SE has the same mounting points as a SE-R
Wrong. The mounting points are quite different. Greg, if you need more pics I'll crawl under and get the stock one pictured as fully as possible to show you how it fits, but since the muffler is MUCH wider than the Magnaflow unit, it will be different.
All in all, I'm kinda pissed cause I wanted my exhaust today.. and I wanted to scare the piss out of some ricers at school (eek, first day) on Monday... oh well. I know these things happen. Much thanks to Greg for calling me back so quickly to talk about it! We'll see if we can get a correct one fired up soon, then vids galore
