Can't hurt any - Unplug your battery for 15-20 mintues, as this should reset the ECU - then for the next couple 100 miles drive easy, letting the ECU know that you want to save fuel, not burn rubber.Anthonysflying wrote:
There is no need to reflash the ECU. The whole problem is a stock car not performing like a stock car. If you want to stretch it though, the previous owner may have tracked the s**t out of it right out of the showroom. Anybody think an ECU relearn might help?
I wouldn't be surprised if they could find out about it. I know I could do it if I worked on 350s all day and then you brought me one running on lean maps.R350Zz33 wrote:but the cobb accessport tuner can put back the stock maps so it dosent void right.
The term hypermiling became famous over this past summer when American gas prices shot through the f#cking roof. Hypermiling is not just one thing, its a combination of doing things while driving. Hypermiling is extreme and in some cases dangerous ways to improve your gas mileage.One being what Richie mentioned, drafting off trucks. In an episode of MythBusters they did and experiment with drafting on tractor trailers. At 55mph with a new Dodge Charger or something similar, at 20' away from the truck, they're gas mileage was something like 50% better than plain driving. It works, but its dangerous and illegal.Inflating your tires above what the manufacturer recommends will help improve gas mileage but make your car more dangerous being that your stopping distances will be increased, the car will feel bouncier and probably handle worse.Coasting through stop signs...saves gas but is also illegal.marlin29311 wrote:
That's not hyper mileing, that'd drafting - they're completely different, and following a semi 2-3 feet back is the dumbest thing you can do on the road, and hopefully if you do it a cop catches you and tickets you for tailgating.
Hyper mileing is coasting as much as possible before coming to a stop.
OP - you want better gas mileage? Here's how:
Don't bring your RPM's over 2500 when accelerating. Do as much driving at one time as possible, as your car runs more efficent over longer periods of use instead of short runs. Consider using a higher viscosity/synthetic oil.
I can easily get my Titan's mpg computer to read 59.9 mpg as well. Just hit the reset button as I'm coasting down from a higher speed. THe real-time meter only goes up to 30 mpg, but I'm sure if it could display more, it would be some absurd number. Your picture proves nothing.R350Zz33 wrote:its not really weather u drive slow or fast its more of smart driving not giving it gas when ur a lil bit away from a stop sign shifting at slow rpms drafting ect proof of smart driving is in my pix.
I most certainly don't drive like a granny. On the highway I usually average between 70-80 mph depending on my mood. I drove from my town in Utah to San Diego in california going 90-100mph the whole time and still averaged 25 mpg lol. Maybe my mods have something to do with it, but I doubt it would make that big of a difference.Sentientbydesign wrote:
27mpg? Do you drive like a granny? I'm getting 21-22 on the hwy. Maybe 23 if I keep the speed down. I know the slightly different Cd and 200lbs isn't making that big of a difference.
Newer nissans only have the screen filter that's built into the fuel pump. They did away with the engine bay one.bmike818 wrote:how about a dirty fuel filter? Wow you are getting really low mpgs with your Z. I thought mine was bad at 23mpg, that's with highway driving.
Goodluck! keep us posted.
Here's a trick.. don't look at the gauge, it's only calculates average MPG.lucsious wrote:ok so i decided to hit the reset button for the mpgand its started to act proper believe it or not..lolhighway i was averaging 20-23 mpg yay!... but still 230-250 miles per tank does that sounds right.?? how many gallons does the z tank hold??
Turning off engine consumes more gas since it has to put extra fuel to light up those cylinders again.R350Zz33 wrote:its a 20 gallon tank. and to the person who said thats drafting not hyper mileing, hyper mileingis not one thing but all thoses things combined shifting early drafting turning engine off at stop coasting coasting with the engine off ...... look it up bud
Seriously, can you expect anyone to honestly believe anything you say with all the blather that comes spewing out of your piehole. It is obvious that you don't know as much about cars as you think you do. Your time here could best be spent learning and not throwing out random bs thoughts that cannot be proved.R350Zz33 wrote:its a 20 gallon tank. and to the person who said thats drafting not hyper mileing, hyper mileingis not one thing but all thoses things combined shifting early drafting turning engine off at stop coasting coasting with the engine off ...... look it up bud
...note takenPapaSmurf2k3 wrote:a fuel filter would have to be really dirty to not work, and even then, it would only affect the car's max performance, not gas mileage. Think about it, dirty fuel filter would limit the ammount of fuel going to the engine, and you use the most fuel at max rpms with the throttle wide open.
I work with a 50k, 100k, 150k system. So manufacture says 40 or 60.. it's 50k miles. Ultimately, you think about it it's a rough guide of when. But if you want to get technical.. it's 60k or 48 months. 04 roadster, 48/12 = 4 years.. yup it's time.PapaSmurf2k3 wrote:50k is nothing special. The big one comes at 60-65k. It includes (IIRC): gear oil change, rear diff oil change, radiator fluid change, air filter change, oil & filter change, and some checkups, etc. I think the spark plugs last 100k but I could be mistaken...
EDIT: here you go: http://www.nissanextendedwarra....html
The newer Z's must be different. My low fuel light kicks in with about 3 gallons left at around 380-420 miles.rmezz13 wrote:Is a 20 gallon tank but has a 7 gallon reserve, i believe, so full to empty is 13 gallons.
