Thanks VitaminT...here's a list mate.
Year/Make/Model:2001 Nissan S15 200SX Spec R(First Reg. Dec 2001)
Engine Hardware:Nissan SR20DET 1998cc DOHC 16 Valve 4 cylinder
Engine Accessories:Garrett GT25R 400HP Ball Bearing TurboGarrett 0.9bar Wastegate ActuatorAVO Tuned Length Stainless Steel Exhaust ManifoldTuned Std ECU with Daughter BoardHKS EVC-IV Boost ControllerHKS Super Sequential BOVHKS Super Fire Iridium PlugsHKS Hi-Power 3.5-inch ExhaustHKS Step 1 Cams 256in/264ex 10.5 liftHKS Adjustable Cam Gear ExhaustSR20DE 63mm Throttle BodyNismo 555cc InjectorsNismo 4.1L/hr fuel pumpCusco Oil Catch CanGenie Custom Twin Dump Pipe from TurboHigh Flow 3-inch Cat ConverterBlitz SUS-power C1 Air FilterApexi GT spec SRS intercoolerXspeed Custom intercooler pipingXspeed Custom 4-inch inlet pipe to turboCustom Cold Air DuctingNissan 300ZX Z32 80mm Air Flow MeterFSE Adjustable Fuel Pressure RegulatorBraided oil lines for turboHigh pressure silicon coolant hoses for turboSilicon vancum Hoses throughout
Driveline Hardware:Nissan 6 speedNissan R34 GT-R Helical DiffBrass Button Clutch1 ton pressure plate (standard pedal feel)
Brakes and Suspension:Endless PadsHKS Super Form SpringsKoni Adjustable ShocksWhiteline Swaybars front and rear powder coated yellow with linksFulcrum Camber correction kit x 2Cusco ALU Carbon OS type strut bar front
Bodywork:Nissan Spec R body kitNismo clear indicator lenses
Rolling Stock:DTM Blitz style dark chrome 18x7.5-inch front and 18x8.5-inch rearFalken GRB FK-451 tyres 225/40/18 frontBridgestone RE540S 245/40/18 rear
Interior Gadgetry:Blitz Dual Turbo TimerHKS EVC Boost Control DisplayGreddy Electronic Warning Boost MeterJDM Pillar mount boost gauge holder
Stereo Components:Rockford Fosgate RFX 8350 head-unitAudio Control Overdrive line driverAudio Control EQX-Series II2 x Rockford Fosgate Punch 60x2 (running mono)1 x Rockford Fosgate Punch 40i1 x Rockford Fosgate Power 250x2Lightning Audio capacitorHSU Research 12-inch DVC SubwooferDynaudio 7-inch splitsAudioart & Technologies Custom RCA leadsOdyssey 800 batteryAll panels lined with Dynamat
Some older pics here:
http://www.xspeed.com.au/ssport/20s15/20s15.htm
