BlackZenki82 »
https://forums.nicoclub.com/blackzenki82-u103092.html
Fri Oct 09, 2009 4:03 pm
i text'd ya back about the 5 lug...
about the lines, i told you what i need as far as fittings... 10mm thread pitch on a short 1/8-3/16 hardline with flares at either end...
same s*** happened the last time i went to Rollins (not saying you, just that shop)... i asked about tuning a ECU, and the old man is like "us that thur wun ah dem neu 4 barrel carburators ahn a chevv-roh-lay? or a ferd?"
go look at your brake lines... you have your caliper, out of that, comes a soft line... at the end of the that soft (rubber) line, it adapts into a metal hard line...
i need that hard line, with a male 10mm fitting on each side... and i need/want 4 of those (only need 2, but might as well do em all)...
