IWannaS15 wrote:Wes, flame away if need be, but is the VH45 into a Y33 a real possibiity? The early VH45 have 320-330 hp while the VK45 is rated at 340hp. I'd say thats just a chip away.
I know what I'll be dreaming about tonight: Y33 + VH45!
I dont see why its not possible... I think that would be areally cool thing to do.. I would CERTAINLY love to have one... Thats something Id love to do someday, is make the Y33 a true Q45. Youd have to convert it to OBDI. I think it would probably drop right into the engine bay (including the mounts maybe), but the wiring would be a nightmare.. You would have to see what the 240 guys do to swap in engines that are OBDI into their 96 and later 240s... I dont know how they do it, maybe you can shed light.. It may be as easy as swapping the engine wiring harnesses, but I wouldnt tell someone its that easy. getting it to work as the factory would (no shortcuts) would not be fun. Youd certainly have to have a complete G50 to steal parts from.
It would be a much better long distance luxury cruiser (than the G50) with the highway passing power that it deserves.. The seats in the Y33 ive found aremore comfortable than the G50s are, regardless of year. Personally (and my opinion is in the minority) i think that the 94 G50 seats are more comfortable than the 90-93. Still, I would take the G50 as more of an M5 sort of car than I would the Y33... Apples and oranges; thats all it is.
Youll notice that the later VK45s have less HP, 335HP in the M, and even less in the new FX.. even at that, i think theyre overrated.. 340ft/lbs of torque. I think the 320HP in the 2006 FX is probably closer to what it actually puts out. The VK45 may seem a litte better because it certainly does have a flatter torque curve...
Remember that when I compare stuff to my Q, i am not considering nitrous. Onyl the ECU... and I did not feel much difference in torque... This was in a Y50 i drove.. Obviously it accelerated faster because of the better trans gearing, but peak torque did not feel much different...
Remember that with OBDI, an ECU'd Q is even competition to OBDII cars. Youll notice that on most nissans OBDII computer upgrades, especially in 2000+ cars do not add HP like they do in the older models.. This is likely because they can run more on the 'edge' since they have faster response times. Youll notice that on the newer things the DINAN ECU's for later models dont add HP, they just make it seem like it (change the driveby wire response, rev limiter, and stuff).
I dont think we've ever concluded what causes the VK45 oil consumption... it could be as simple as carbon build up like it is in the northstar engines.
