G50 + 2JZ + Radiused Fenders + Euroline SL's = The new build
yodawill2000
Car: 94 Infiniti J30
:werd:
OwnerCS
I can't tell from the after pictures, but I guess you completely removed or cut out part of that battery shelf?
G50 Q
No, it just just surface rust.. hit it with a DA to smooth it out. The car is surprisingly rust free. There is even no rust in the rear 1/4's although it wouldn't matter anyway I guess since they be getting cut out..
I think the pic makes it look worse than it actually was.
OwnerCS
That's good for sure.. I see you are plugged into some serious metal fab talent out there.
Do you know anyone out there who could make a G50 lift kit -- 1.5" for the front and 1" for the rear?
I'm plagued with speed dips out here in suburbia.. They are the opposite of a speed bump where your wheel sinks down and it causes lower built cars to bottom out..
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Really a badass job man! Don't sweat the haters, it's easy to be a chair jockey. Frankly, they should have more respect for the fact you're even able to do it! Cool idea and please keep us posted.
Just so you know, we REALLY eat up videos of finished product, wink wink :)
Nice work, yes the Toyota logo hurts badly, but like most 25-40 year old men, I had many wet dreams about Supras in my youth so I still have respect for the Toyota name, in some applications.
G50 Q
Thanks!
I spent some quality time with just me and the Q today :) I got the radiator situation figured out, I'll be running the OEM G50 radiator and custom lines. The OEM radiator is huge, so it should be more than sufficient to cool the new engine. I made up some custom Radiator hoses as well and got everything mocked up.
I also managed to figure out the heater hoses, and get them installed.
All little stuff but necessary. Getting close to first start time!
Oh and quality pictures will be up next week! Videos will be up shortly.. speaking of videos, here is one of our last demo car:
[youtube]http://www.youtube.com/watch?v=33rtT53J7PA[/youtube]
xKnownShadowX
Car: 94 Q45a
I thought I was the only one to think of dumping a 2JZ in a Q45. Well now I can't do it since someone else did.Glad you are too since mine would've been done later in the years.Can't wait to see it running. :naughty:
G50 Q
Ok.. more updates! Excuse how dirty the engine bay is!!
Got the High Pressure Power Steering Line back:
Decided to use the factory air guides, I forgot to take a before picture... but they were pretty nasty. Custom Chrome got them looking brand new!
We replaced the water pump with a Supra Twin Turbo unit to eliminate the pesky hydro clutch fan and had to pick up a pulley for the new pump, decided to go ahead and get all 3:
Got the Manifold and turbo mounted, also test fitted the downpipe:
Oil feed and return lines are made:
Current Engine Bay Shot, radiator is mounted here:
The refreshed factory air guides:
JNguyen
Car: Infiniti Q45
VW Golf
The car is looking awesome man!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
G50 Q wrote: Decided to use the factory air guides, I forgot to take a before picture... but they were pretty nasty. Custom Chrome got them looking brand new!
Where can I find "Custom Chrome"?
G50 Q
Here ya go, ask for Aaron:
http://customchromeofva.com/
Infinitiguy19
So its not a chemical....
What did the service run you?
G50 Q
Infinitiguy19 wrote:So its not a chemical....
I think it was $125... but I had some other stuff done by them at the same time so I could be wrong.
G50 Q
Got the I/C pipes mocked up today. Just need to get a few pieces welded. I forgot to snap some pics of the hot side before I took everything off:
G50 Q
So, the JDM Headlights came today. The goal is to make them look like this:
Unfortunately, that isn't going to happen right away... haha USPS decided they would rather break them :(
G50 Q
Well believe it or not, I was able to source a new JDM headlight lens in the US for the one that USPS broke. It was shipped today, so I thought I would go ahead and start on the non broken side. Enjoy the pics, I think it turned out great:
Cleaned the housing as good as it would get and removed all of the plastics and lights:
Here is what the light looks like from the factory:
Baked it in the oven for a bit and removed the outer lens. As you can see it is clear:
A little more baking will allow you to remove the inner lenses and trim ring:
Inner lenses removed:
I'm not sure how other people do this set but I decided to paint the inside of the headlight housing black, since it will be visible now. I used to be the same color as the outside of the housing:
Almost finished, just need to repaint the edges of the lens as most of the oem paint was flaked off:
Final Product after baking:
mrpeeb240
Car: 99 Q45t 200k
beautiful finish! very nice touch with black paint inside and out, what adhesive did you use when reassembling and baking?.
Brent
G50 Q
mrpeeb240 wrote:beautiful finish! very nice touch with black paint inside and out, what adhesive did you use when reassembling and baking?.
Brent
I just reused to OEM goop, it seems like it was in good shape and plenty of it left to use.
Hopefully it will start this week! Got the I/C piping back and installed, the wastegate is installed, downpipe installed, P/S lines ran, and res mounted. Still need to fab a throttle cable bracket.. but pretty much done engine wise!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Looks awesome!! The JDM lights really help the look of the car, amazing how that combined with fresh paint and other things how modern and classy the car still looks!
It would be ideal IMO to try and put those lenses on the stock USDM headlights, so the beam kick up is on the correct side.. I rode in a Q with JDM headlights and it just looks kinda weird, not undriveable but strange.. I bet you could use the adjustment to get it close to stock.
G50 Q
Well the scatter shield on the USDM headlights is built into the stock lens, and I removed the scater shields on the JDM ones, so aside from adjusting, the light output would be the same. Although the USDM's would look odd with these lenses because they are not 2 seperate pieces inside, It's one large one.
A projector retro might bein the future, depending on how the light output turns out.
G50 Q
First Start video should be up by the end of the week!
TheRealNap0le0n
Car: 1998 q45
this is nice.... im actually debating saving the money i was gunna use to put my RB25 in my S13 coupe and buy a Q and putting it in there instead...
or just buying another RB but like you automatic lol..
as much as i love V8's the sound of a straight 6 turbo is seeeeeexxxyyy
G50 Q
I got the wiring harness back yesterday. With any luck I will be starting it today!
G50 Q
First Start!! Thanks for everyone who helped me find the correct realys, and a huge thanks to Ben at Freed Engineering for putting up with my stupidness!!!
Short Vid:
[youtube]http://www.youtube.com/watch?v=rlFwDJ7VYGU[/youtube]
G50 Q
Got the headlights and OEM bumper mounted untill the aero arrives! All of the wiring is finished up, AFC is wired and the Aristo auto trans is wired (Thanks to Ben @ Freed Engineering!) Also test fitted the newly refinished air guides, please excuse the gigantic battery!:
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
Wow man, That's incredible. Congrats! Where did you source your JDM headlights? I wanna copy your idea, I think it'll make my HID's look super-dope...
jj702s1
Nice...
G50 Q
^ Thanks!
Lokim wrote:Wow man, That's incredible. Congrats! Where did you source your JDM headlights? I wanna copy your idea, I think it'll make my HID's look super-dope...
Tahnks man, I got the headlights from Yahoo Japan Auctions.
jroo
Car: 2004 Nissan Pathfinder
this is shaping up to be my favorite q45. I love the 2jz. If this fits, I would think there is no question that an LS motor will go in. I kicked around the LS idea when one of my boy's dad Q died. We did some early measurements and thought it would go. Length wise the 2jz is longer than the LS, so the idea may be back on!
G50 Q
Thanks!
A LSX should fit easily. Do it!
