Gearboxes are different and so are the mounts. It would be wise to buy that mount from the dealer or you will get disappointed when they send you the wrong mount because they will.livelyjay wrote:Thanks Maz, I was hoping it was that easy.
Why would I need the transmission mount if I'm going from manual transmission to another manual transmission? Two auto parts sites online show the same part number between the 87 and 88 Pulsar SE.
That's not entirely true about the transmission being the same one as the maximas. It won't bolt-up because the bellhousings are different and even if you wanted to use the gearbox from the maximas, it will require modification. You need to get the transmission from a pulsar or a 1987-1989 nissan stanza (ratios are different).livelyjay wrote:If this is the same transmission that's in the VG30 Maxima, could I get that transmission and mount it to the CA18DET (and get all the other stuff for the CA18DE)?
Again, don't believe the internet. Those axles aren't for the pulsar you wish they were for. They are for the pulsars with the E and GA series engines (different transmission family).livelyjay wrote:I'll double check the axles, but hey, for $42 a piece might as well get brand new ones with new boots than have one get messed up while I'm driving. Better to have the piece of mind that they are new.
Must be specifically for the pulsar. None of the others will work. As for the phantom grip device, it works and it's in one of my cars that puts out more reliable power than most on this forum. BTW, it is in a FWD pulsar box.livelyjay wrote:I plan on buying one of Phantom Grips, I just don't know when or how I can fit it into the budget.
Back on topic, what FWD axles are compatible with the CA18DE transmission, or are the ones from the Pulsar SE the only ones? I've got a guy looking into the pedals and other parts, but axles are iffy.
Dee, would you recommend the Phantom Grip over the RS5F51V (I think that's it... the VLSD box from the Maxima)?boost_boy wrote:Must be specifically for the pulsar. None of the others will work. As for the phantom grip device, it works and it's in one of my cars that puts out more reliable power than most on this forum. BTW, it is in a FWD pulsar box.
Dee
I would keep the pulsar's box for track purposes because it's ratio is nice for dragging on the streets or strip. I use to have a stanza gear box and that gearing is good for making vipers and R35s sweat past 150mph (sucks for drag racing though). Now I use the Maxima's gearbox with a gear or two from the pulsar (can't remember which one) and it gets the job done plus. For the cost of the maxima gearbox swap, go get the phantom grip as the maxima or stanza set-up will cost you the cost of a CA18 motor set-up and that's only if you do the work yourself.mazikowski wrote:
I can speak from experience that the CA16DE transmission does not handle boost well, especially with a better-than-OEM clutch... My CA16 transmission lasted 6 months on an OEM clutch, then I replaced it with another CA16 and put in a SPEC Stage 3 CA16DE clutch (rated at 190 ft-lbs, IIRC) and that transmission lost it after less than a month. I guess that's what I get for being stubborn and not listening to the advice I was given...Liquid_Neon wrote:I dunno if this has been said... DO NOT USE THE CA16 transmission... if you can avoid it. They have a smaller flywheel and have been known to not handle boost well at all. If you can source one, please do yourself a favor and use a CA18 transmission. Call a boneyard and get one and check it over.
I blew mine up years back and got a new one for only $250.
I got a spec clutch specifically for the pulsar btw, i dunno the part number but its easy to find.Also, i have swapper motors 3 times now in the KN13 chassis... so if i can offer anything, jsut ask
They are not the same. You'll need to go through a nissan dealer for the correct transmission mount. You can take my advice or you'll be treading water for a long time trying to track that down. And please don't buy used motor mounts or you'll be sorry as most of them are very old and brittle.Fleemer wrote:i'm pretty sure ca18de and ca16de mounts are the same.
Its prolly best if you confirm at nissanexa.com
