livelyjay »
https://forums.nicoclub.com/livelyjay-u16717.html
Mon May 10, 2010 5:18 am
I ended up buying some 3/8" clear plastic hose from Home Depot. I cut the hose at an angle and was able to force it into the filler hole. I then drilled a slightly smaller hole in the cap of the trans fluid bottle, stuck the hose in, stabbed a hole in the bottom of the bottle, and let gravity feed it in, almost like an IV. It took the fluid a good 15 minutes per bottle to feed in, but it got in nonetheless. Dropped the car down, fired it up, threw it in reverse, and backed out of the garage on the first try. After letting the car warm up and filling up the tires, I took it for a short drive up and down my street. It feels great. The clutch pedal is a little sloppy, so I might have to bleed it again, but it's working.
Thanks for the help everyone. I wouldn't have been able to accomplish this without your help. I still have to wire up the transmission sensors, but that should be easy compared to the mechanical side of things.
