livelyjay wrote:I ordered an OEM clutch because I got it new for $60 shipped. I can then determine if the transmission swap works before committing the money for the engine swap. Also it enables me to drive the car around while getting the engine itself ready. Once the clutch gets here I'll start getting everything ready to pull the current transmission out.
So, any help on the bolt identification? I figured the 7 bolts are for the transmission mounting, not sure where each goes but that should be easy enough to figure out when I get it next to the engine. The trans itself if looks like there are supposed to be 8 bolts however, and I only have 7.
Where's the CA18's starter because you are definitely going to need it. As for the bolts I'll try:
Of the longer bolts, the first one on the left is the bolt that goes throught the upper part of the transmission/engine bracket which is used to fasten all of that stuff together.
The 2nd long bolt is for the radiator side of the bellhousing in the middle.
The 3rd bolt is for the transmission mount. It is the one the secures the mount to the gearbox, not the rubber mount.
The 4th bolt is for the starter and this bolt is the only starter bolt that bolts from the surface of the bellhousing.
The 5th and 6th bolts are use to secure the top of the bellhousing to the engine block.
The 7th bolt is the lower starter bolt which is fastened from the backside of the starter.
Some bolts are missing, so I can't really help you on the rest as I don't want you to fault me if you screw-up something. The three little 12mm bolts on the bottom left are 3 of 6 of the pressure plate to flywheel bolts. You already know which ones are flywheel bolts. The oem clutch is worthless my friend. It will burn-out quickly and dropping the transmission is not fun. I can drop them in less an hour and I've done this more times than you probably have years on this earth, but still it's no fun. Hope this helps.......
Dee
